The copper pipe connecting to the trap that connects to the cast iron waste is the drain line from the dishwasher above.
Since potential contamination from siphoning is the problem with the dishwasher drain line, this looks to me like it would be OK, but it also doesn't really seem right. It wouldn't be installed according the manufacturer's instructions, but what exactly is the defect? Dissimilar metals in contact? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America) |
How is the copper line being connected to the top of that trap?
Is there an open gap or is it some how sealed? |
Trying to find wordage but if the drain does not have a high loop too than I think the water will just drop out of the dishwasher with a siphon like effect.
Some brands have a loop built in , but some do not. Where is the plumbing vent? |
I didn't get a good look at the connection since I knew I was going to recommend correction for dissimilar metals and non-conforming installation. I wish now that I had jsut to satisfy our curiosity. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Looks like the copper makes a Hi Loop to me Kenton before it goes into trap. If an Air gap is not required a Hi Loop is acceptable.
You might be able to defect out the copper to trap connection as I can not tell from the photo how exactly that is made. |
Kenton it is not OK for the water to completly drain out is what I am saying.
The seals will dry up. The reverse loop has two reasons. Cross contamination is one, and two is so the seals still have water in them . C apish! (think running a spa tub that has no water) |
I've never seen a production adapter for this situation so I'm thinking that it's something the plumber invented. I'm going back up to retrieve the radon monitor. I'll get a photo. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
No, but it's an older model, Bob. I can find out tomorrow. What would I do with that information? Is there an easy way to find out if it has an integral anti-siphon device?
Intergal anti siphon is to protect the city water from you. Hi loop (Air gap) is to protect you from yourself. |
I thought the integral was an air gap device built into the back of the cabinet that prevented dirty water from siphoning back into the cabinet interior and contaminating the contents.
I just saw that as I dismissed it as another line (***=uming the DW was straight above. Still may be in the wrong place. Kenton you can get mnfr instruction and find out if it is a high loop maybe. Since that could end up time consuming ,it is much less intensive to call for a high loop rather than look up every unit you come across. There are a few appliance look up sites but it could end up like when you need to find a Manuel for an 30 year old Furnace. (edit) I can't believe they edited A-s uming |
dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
There is not a vertical drop with the installed 'T' in the copper DWV , more apt to have a problem there with waste plugging up the trap. The 'T' should have been turned up 90*, maybe something else used it previously and they decided to use the existing system as is.
I would question whether the manufacturer would allow an additional length of small diameter run, especially copper pipe. Next, I expect that the manufacturer requires their drain line to be installed to a DWV which the copper tubing is absolutely not. There is also another fitting on the copper on the upper right side of the pic which may further reduce flow by increasing restriction. There is probably a good amount of corrosion going on inside the copper pipe . It just ain't right, IMHO. http://www.copper.org/applications/p...th_table1.html |
P trap NOT designed for that application! Incorrect use of piping. What about materials fellas? I see copper P traps but mixing a common sink P trap (possible) corrosion problems and sealing issues. This is a quick fix deal without professional design in mind. What happens with the pipe leaks regardless of the Dishwasher connection...
I just wrote it up as an incorrect installation and the buyer can have a tech figure it out if it bothers him enough. It's not really right, but I think it functions OK. If it fails, I guess the failure would be the dissimilar metals in contact causing slow, long-term galvanic corrosion. Since the corrosion only happens when the metals are electrically connected with moisture, I think it'll last a while. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Slope of waste drain line. | mlong | Plumbing Inspections | 5 | 4/23/08 10:54 PM |
| Dishwasher line to trap | hspinnler | Plumbing Inspections | 6 | 9/19/06 11:37 PM |
| Exploding Dishwasher | mbledsoe | Plumbing Inspections | 8 | 2/28/06 8:13 AM |
| Dishwasher Drain Line | msimmons | Plumbing Inspections | 9 | 1/19/06 12:27 PM |
