Is this incorrect. There are three traps that Y into the drain line.
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Not allowed by the UPC. . .
Tough question. Traps in series are prohibited, these are parallel. IRC 3107.1 says ok for 2 traps on one trap arm; UPC says 1 per trap arm; question is whether the Y is part of the trap arm? Tricky.
Harry "Bud" McClard Serving All of New Hampshire |
Thanks Jeff; I had gone for coffee refill before hitting "post". AND, think of all the extra storage they gain by cleaning that mess up!
Thanks guys
Yes, it is.
All piping from the trap-weir to the vent is part of the trap-arm. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I personally do not see a real world issue with the above.
The drain and vent should be what...... 2-3 inches behind the "Y"; probably not much of an issue except on paper.
| Walk-off Unassisted Triple Play | jferry1 | Miscellaneous Discussion for Inspectors | 0 | 8/23/09 6:21 PM |
| Illegal traps | dmacy | Plumbing Inspections | 1 | 5/22/07 10:19 PM |
| Air Admittance valve? 2 traps | aharper1 | Plumbing Inspections | 5 | 9/24/06 7:42 PM |
