Is the drain line from the TRP valve on a attic installed hot water heater allowed to drain in to the pan if the pan is plumbed
Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
yes, Peter
In LA it's allowed (per the IRC), but not in states where the UPC is enforced, such as CA.
Thanks!
NO!
2003 IRC: Quote:
I understand your logic Manny, but I'm not sure I agree with your interpretation.
The UPC is much more specific. . . 510.8 Relief Valve Discharge. Discharge from a relief valve into a water heater pan shall be prohibited.
Jeff,
Wish I had a copy of the UPC. Any links to an online version? Basically what I am referring to is the size of most pans placed under water heaters are very meager. Most are barely big enough to hold a gallon or two of liquid and the edges are barely an inch high. If a TPR pops there is going to be a lot more water flowing than the pan can handle. Also it will wind up splashing everywhere when under pressure. Probably a better explanation comes from the IRC Commentaries: Quote:
As I said, I understand and agree with your logic, however, your interpretation is not in line with common understanding as I know it. I believe that most code authorities agree that it is acceptable to discharge into the drain pan when referencing the IRC.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 5/4/06 at 6:54 PM.. |
It's allowed down here in San Diego.
I assume you mean that some of the AHJ's turn a blind eye to it Russ. San Diego County follows the same California Plumbing Code as Los Angeles County.
Russel,
www.municode.com does not list San Diego but the San Diego County WEB site does provide a reference to their codes www.sdcounty.ca.gov/dplu then to www.amlegal.com/sandiego_county_ca/ . It appears San Diego county follows the California Plumbing Code which does prohibit this (see Jeff's reference above ). |
Remember that the AHJ, and his/her interpretation, has the final say-so. NACHI 2005 U.S. Member of the Year
There's really no other way that this can be interpreted.
If that were the case, we wouldn't be having this discussion. Witness: Quote:
The IRC is not as clear as the UPC/CPC.
It is quite clear by California Standards. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| 2 water heaters, combined TPR and pan drain line | lfoster | Plumbing Inspections | 11 | 12/18/07 11:23 AM |
| Supply Line Question | hmcclard | Plumbing Inspections | 5 | 10/29/07 10:42 AM |
| Plumbing vent | cbono | Canadian Inspectors | 23 | 10/13/07 10:58 AM |
| Capped drain line vent | rdawes | Inspecting HVAC Systems | 3 | 4/21/07 7:00 PM |
