Old 10/14/08, 11:30 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Tub Question
This is a stub out for a tub. I usually see just the cooper pipe stubbed out. I am not familiar with what this is. I thought one of you could identify.
http://i148.photobucket.com/albums/s32/Xillaw/Bathtub-Spout-5.jpg
Thanks
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 10/14/08, 11:50 AM
Dale Duffy's Avatar
Default Re: Tub Question
Greg, that is stubbed out for a particular brand of spigot, so 99.9% will not connect to that, a piece of copper will need to be soldered on that with a coupling after that contraption is removed tight to the surround--:)))
Old 10/14/08, 12:31 PM
Greg Bell's Avatar
Thanks Dale,
That is what I thought but wanted to make sure.
Greg Bell
Titusville, Fl
02111507
Old 10/14/08, 12:58 PM
mnahrgang's Avatar
That looks like the inside of an old spigot to me. I had the same thing happen to me about a month ago when I tried to replace one that was leaking. As I twisted the spigot off, it broke and left this (actually something similar) attached to the pipe. It took a large channel lock and a firm grip to twist if off the stub out in order to replace it.
Mark Nahrgang
www.HeyMark.info
Old 10/14/08, 1:31 PM
Greg Bell's Avatar
Thanks Mark,
I let the client know of your comments and suggested that he give it a try.
Greg Bell
Titusville, Fl
02111507
Old 10/14/08, 2:51 PM
Barry Adair's Avatar
Greg,
Remind them righty tighty, lefty loosey, running hot water or hair dryer preheat to loosen any gunk works well also, as long as the aim at threaded coupling and not back into the wall
Oops don't do both at the same time, duh
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/14/08, 2:57 PM
Dale Duffy's Avatar
Originally Posted by badair View Post
Greg,
Remind them righty tighty, lefty loosey, hair dryer preheat to loosen any gunk works well also, as long as the aim at threaded coupling and not back into the wall
Good Luck..I have tried unsuccessfully at this fiasco a few times, it is so much easier saving my patients for more important things----
Cut, coupling, solder, slide on new spigot-----
Old 10/14/08, 7:47 PM
Greg Bell's Avatar
He couldn't get it too turn off. He is calling a plumber for repair.
Thanks all for your help.
Greg Bell
Titusville, Fl
02111507
Old 10/14/08, 8:05 PM
Greg,
Soory Barry I could not resist that nerve spark;
That saying only applies to plumbing here, does not work for acetlyene, propane fittings nor for some water districts street shut-offs.
Just thought I would mention.
And the rest of you, take that sucker off and buy a new spigot, and call a plumber before you break it.
Nice call Gregg.
Marcel
Old 10/15/08, 12:45 PM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
That sleeve is pretty common around here.It actually allows for easier installation of the spout because it in sures a snug spout to wall fit without worrying about leaks.
The "O" ring keeps it from leaking and the threads control the distance the spout is thraded.
These sleeves are brass and are supposed to be soldered on to the copper.When sweating ,the "O" ring must be removed to prevent melting.
The extended copper in the photo could have been trimmed a little for a neater job but isn't effecting anything the way it is.
If you ever get a chance to use a sleeve like this you will immediately see the advantage over just a threaded sweat adaptor.
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
Question for all... Bob Hopton-Jones General Inspection Discussion 9 4/6/07 7:43 AM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/20/07 11:56 PM
