Old 1/27/07, 5:08 PM
brepanshek brepanshek is offline
Please Note: brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Tub trap
I saw this today, this is a drain line coming from the tub from above and hangs down about 18" then a trap and gooes into the main sewer line. Not sure if this is ok? Give me your thoughts thankstub-trap-dscf0012-small-.jpg.JPG
Old 1/28/07, 10:47 AM
Default Re: Tub trap
I need your advise on this one guys, I always get great reponses from here, the more I learn the better HI I become, anyone have a comment on this situation?
Old 1/28/07, 11:03 AM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
Looks fine to me. Just a little different. I have never seen one that far down before but IMO, should work just as well.
John J. Passailaigue Jr.
NACHI05062580
Auburn Home Inspection
Auburn, Alabama
WAR EAGLE!
Old 1/28/07, 11:21 AM
Jeffrey R. Pope's Avatar
24" is the maximum allowable length for the tail piece - except for a washing-machine standpipe, which can be 36".
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/28/07, 11:48 AM
THANK YOU THANK YOU Jeff where did you get your finding please
Old 1/28/07, 6:25 PM
Hey Jeff i have the code book and the best I can find is under section P3105.3 (5) Is this what your talking about? So do I state something within my report?
Old 1/29/07, 6:25 AM
staylor5's Avatar
staylor5 staylor5 is offline
I don't see a problem
Old 1/29/07, 1:02 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
If that 2" above it is a vent then it may be ok. If it is a drain and they used this as a wet vent it would depend on the plumbing code. In that case, under UPC, it would not be legal.
Old 1/29/07, 8:39 PM
UPC 910.5
I can't find the IRC section, but 3105.3 is a different animal - a vertical leg.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/30/07, 5:57 AM
i'll keep looking but for now i stated nothing on the report.
Trap primer valve dmacy Plumbing Inspections 2 12/27/06 1:21 PM
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 12:17 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/14/06 11:00 PM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 5:41 PM
