Commercial building water heater had a recirc. pump because of distance to fixtures. Pump plugged in but not running. How in the world would you fix this. Turn it up?
I would write in my report that the water is to hot and that you have not tested the pump as it was not running. I would also state that it looks like there is a blow back on the water heater and recommend they get them immediatly serviced by a qualified person. Roy Cooke Like your print on the pictures what program are you using Thanks Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Scott,
The areas you have circled look more like water stains than soot. 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
I did a smoke test. Smoke was not going up the vent. After picture was taken I wipe some off, awful easy to get off. And I could turn the end of the pump with my finger. Took a long time to get hot water at long run fixtures also.
Thanks Roy for the chart I'll send it with the report.
| How to Turn a marketing Plan Into Legislation.. | jbushart | Legislation, Licensing & Legal Issues for Inspectors | 0 | 6/17/07 9:15 AM |
| Turn on the water??? | bkirby | Plumbing Inspections | 27 | 2/6/07 5:41 PM |
| Regarding E&O deductibles: How to turn a complaint into a marketing opportunity. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 12/2/06 2:12 AM |
