jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
How many elbows are allowed on a TPR drain line. This line had 5 elbows (some 45's) just within the water heater closet.
I do not see anything in "Code Check Plumbing" about it.
I don't like the looks of it but, that doesn't make it wrong. Others may have better info. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
It appears the line might be reduced in size, that is wrong.
I don't like to see any installation with piping across the front of the appliance, as it generally makes the removal more difficult ( obviously the plastic piping is easily removed ). The fact that they are using either cpvc or pvc as the extension piping from the relief valve is a problem. Neither is rated for the potential discharge of the hot water when the relief is opened. The fittings could soften and the discharge piping could be compromised. The number of 45's in this case is not a problem that I am aware of.
Gerald Wilcox House Check Home Inspections "He is no fool who gives what he cannot keep to gain that which he cannot lose." Jim Elliot 1949 Gerald Wilcox Harvey, ND CMIA, RMT www.housecheckhomeinspections.com www.homeinspectorinnorthdakota.com 701.324.4075 Minot, ND Home Inspections Devil's Lake, ND Home Inspections Bismarck, ND Home Inspections Jamestown, ND Home Inspections Home Inspector in North Dakota North Dakota Home Inspection |
A couple of links on CPVC: http://www.ppfahome.org/cpvc/faqcpvc.html http://www.plastemart.com/upload/Lit...VC_Pipessp.asp Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
Where does it go after entering the wall?
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
http://www.nachi.org/waterheaterdisc...leased2007.htm
Water Heater TPR Valve Discharge Piping mini-course. Take it (free and open to all |
Thanks Jason, for the documentation. This was always considered poor practice, for the reasons I mentioned by us former plumbers. I see it is allowable and I appreciate the info.
Max of 4 90 deg elbows and 30 feet of discharge piping.
reference here as well http://www.nachi.org/forum/f22/code-ref-tpr-valve-piping-8003/ ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
| 2 water heaters, combined TPR and pan drain line | lfoster | Plumbing Inspections | 11 | 12/18/07 11:23 AM |
| At least they put in a drain line | dbush | Electrical Inspections | 17 | 11/2/07 12:03 AM |
| Evaporator drain line | lfoster | Inspecting HVAC Systems | 3 | 7/18/07 8:35 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
| Dishwasher Drain Line | msimmons | Plumbing Inspections | 9 | 1/19/06 11:27 AM |
