Wondering if this venting configuration is OK or if there could be an issue with a larger WH unit upstream of a smaller one? This is in an unfinished attic.
There are other issues there, but im just wondering if the venting is all good Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
| Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America) |
No, the venting is not good. The single wall pipe in the attic would be enough to refer it out let alone the lack of supports, eh?
Did you fire them both up and check for backdrafting? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
From what I can see, Ken was telling Smith it was getting hot in there and to take his jacket off, and looks like they both agreed.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Your right- there already was some other goodies, leaking gas valve, possible asbestos insulated pipes ( could be combined with cloth covered insulation) Not to mention they were not wearing their coats. Both units have that plastic TPS discharge pipe. The single wall doesn't touch any wood or combustibles though. I was considering if the set up would allow for back drafting. Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
Single wall pipes need 6" of clearance. Taped pipes are not acceptable, needs mechanical connections(ie screws). Check for back drafting at the top or the water heater with a mirror(condensation).
Now if you found all that other stuff, they need a specialist anyway. |
Looks like inadequate rise/run for a naturally drafted appliance too.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
The whole building was full of home owner DIY SHORTCUTS Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
That should also be a Y connection Joe.(did someone mention hangers?)
The gray panels in the background may be asbestos transite too.
The main pipe must be equal to the largest connector +50% of the others.
anyone have the code for rise on exhaust?
M1803.3 of the IRC
The horizontal vent run must be pitched down toward the terminal end
1/4” per foot for condensate drainage. The slope applies to the entire length of the horizontal vent run. Failure to pitch the vent run properly may damage the heater due to condensate running back into the unit. Use non-combustible supports on vent pipe. Support lateral runs every six feet (1.8M). Support vertical runs of Type B double-wall vent pipe in accordance with the requirements of the pipe manufacturer. Support lateral single-wall pipe in accordance with accepted industry practices. Do not rely on the heater for support of either horizontal or vertical vent pipe. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Were the CO levels checked??
Should be, but that does not always show properly and this is in the attic where hopefully one finds circulation.
Needs to be re piped anyway. |
| smelly well water | afrost | Ancillary Inspection Services & Additional Topics | 26 | 11/21/07 7:30 PM |
| Got this email... No such thing as hot water heaters. | gromicko | Plumbing Inspections | 46 | 8/26/06 2:21 PM |
