Old 5/29/09, 10:52 PM
Bob Elliott's Avatar
Default Two water heaters (A Touching Story)
I am wondering if there is anything wrong with two water heaters touching ,though I am recommending drain pans as a side note.?
Seems that though there is a floor drain in front of them the floor slants towards the bedroom door in back of them.
P.S ...1st floor slab
Find an InterNACHI certified Rhode Island Home Inspector (and anywhere else in North America)
Old 5/29/09, 10:58 PM
Default Re: Two water heaters (A Touching Story)
Only if they are married...
Old 5/29/09, 11:22 PM
Jeffrey R. Pope's Avatar
Generally, it's not a problem. The clearance requirements are listed right on the units. Usually it's 0" sides and back.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/29/09, 11:31 PM
Thanks
Guess the only problem is finding room for the drain pans.
Flip special bought in January with the seller / flipper there.
Old 2 flat
Old 5/30/09, 4:03 AM
Brian E. Kelly's Avatar
They look same sex to me Jae............
Old 5/30/09, 8:49 AM
William M. Corbett's Avatar
William M. Corbett William M. Corbett is offline
I would not normally think any thing of it either However for the sake of this discussion, with the combustion draw at the bottom of the water heaters, I wonder if that may cause some issues.
Bill Corbett C.H.I.
Magic City Inspections LLC
InspectingtheUnexpected.com
Old 5/30/09, 9:29 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sniff, sniff....
That is touching.
Old 5/30/09, 9:46 AM
Actually they still need to add the room air requirement
The cat 4 unit is to the left (note panels are out)
Old 5/30/09, 12:24 PM
There are water heaters in California...
What might cause this many cracks? bhamilton Structural Inspections 15 2/25/09 12:44 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
