Old 1/19/10, 8:01 PM
Rhys Malen Rhys Malen is offline
Please Note: Rhys Malen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Types of piping
I'm fairly new and I don't have a construction background... so, I'm still a bit confused about the easy ways to tell the difference between:
painted/dirty copper piping,
galvanized steel piping,
painted galv steel,
black cast iron,
brass fixtures
Sometimes they can look similar or discolored so I find it rather difficult to be 100% certain.
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/24/10, 8:22 AM
staylor5's Avatar
staylor5 staylor5 is offline
Default Re: Types of piping
look at fittings. the copper fittings are more stream lined. Gal is usually silver in color.
Old 1/24/10, 8:38 AM
Here is a gallery of different pipe corrosion failures, and also shows different types of piping material that may help.
http://www.corrview.com/corr_07.htm
Old 1/24/10, 9:19 AM
ldapkus ldapkus is offline
You may need to scrape some paint off in an inconspicuous area to see the surface. Don't forget lead piping used as supply into homes is easily recognized because it is very soft and easy to scratch.
Old 1/24/10, 1:24 PM
Bob Elliott's Avatar
Also usually has a noticeable curve.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Bonding both hot and hold supply pipes kshepard Plumbing Inspections 22 5/4/08 8:00 AM
Bonding Piping 101....Good To Know ! pabernathy Electrical Inspections 37 4/28/07 11:25 AM
plastic piping? Scott Schultz Plumbing Inspections 5 3/28/07 1:40 AM
