Old 4/19/10, 3:55 PM
Kenny Rigler Kenny Rigler is offline
Default Unique Plumbing Install
Hey Folks-
Anyone have an idea of why they might have done this? I don't know if they were going to put an AAV and decided not to or what. Would this configuration create any problems?
Thanks!
Kenny
unique-plumbing-install-img_6546.jpg   unique-plumbing-install-img_6550.jpg   unique-plumbing-install-img_6549.jpg
Rigler Home Inspections
Hays, KS 67601
785-656-0272
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/19/10, 4:08 PM
mnahrgang's Avatar
Default Re: Unique Plumbing Install
No, that's right. That loop will help prevent siphoning in a situation where an AAV isn't allowed and vent is needed. I can't explain how or why it works, but I've seen drawings/diagrams showing that same exact thing.
Mark Nahrgang
www.HeyMark.info
Old 4/19/10, 4:17 PM
Jeffrey R. Jonas's Avatar
The principle (assumption) is that the amount of air contained within the "loop" is sufficient to drain a full bowl of water. I have seen plumbers increase the pipe size on the loop to accomodate 'both' bowls of water being drained at the same time. As the water moves through the drain, it draws the air with it, and 'theoretically' creates a vacume break. I'm not 100% sure I agree, but I have yet to see a problem with this setup, if done properly.
Old 4/19/10, 4:36 PM
Brian E. Kelly's Avatar
Originally Posted by krigler View Post
Hey Folks-
Thanks!
Kenny
Typical Island Sink Drain configuration.....
Old 4/19/10, 6:52 PM
Michael Larson's Avatar
Not typical at all sir! Look again.
Michael Larson
Hudson, WI
Old 4/19/10, 7:48 PM
Chuck Evans's Avatar
It's missing the required cleanout on the "vent side", but it's close enough that I would not make an issue out of it, at least not on an old ABS installation like that. I never get to see the lateral connection, because it's always under concrete.
The pipe in the loop is upsized, not to provide a sink's worth of air volume, but to ensure that the stream of water coming from the smaller fixture drain cannot completely fill the pipe and create a siphon. This ensures that air can circulate through the loop with the water to prevent a vacuum for forming. If the loop is not a larger diameter than the fixture drain, it's not configured properly. You should be able to drain any volume of water through this arrangement without siphoning.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 4/20/10, 2:03 PM
Thanks the picture Michael...I've never seen that before. Is that a better install than having an AAV? From your picture, why not just install an AAV instead of do the whole loop?
Hays, KS 67601
785-656-0272
Old 4/20/10, 2:20 PM
The AAV is a mechanical device and subject to failure and needs periodic replacement, so I would say yes.
Michael Larson
Hudson, WI
Old 4/21/10, 9:34 PM
Banned
In that illustration, with a CO installed at the left end of the horizontal leg of the vent pipe, that should be the only arrangement allowed.
Old 7/10/10, 10:14 PM
David Garton's Avatar
David Garton David Garton is offline
I have that same setup on my kitchen island, it's worked fine for 20yrs.
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
