Old 6/30/14, 11:40 AM
Mark Raumikaitis Mark Raumikaitis is offline
Default Unsafe water heat vent
This morning's inspection of a modular structure, vacant estate home, seller indicates water heater was recently replaced due to leaking. Contractor left a mess of the membrane and insulation under the structure and when the exhaust vent for the gas fired water heater wouldn't fit and line up correctly he threw away the extra parts and just left it as is. You could smell the exhaust when you entered the room. If the installer has a license he should loose it though I suspect that a "handy man" was used instead of a licensed plumber or gas fitter.
unsafe-water-heat-vent-img_0047.jpg   unsafe-water-heat-vent-img_0034.jpg   unsafe-water-heat-vent-img_0108.jpg
Mark Raumikaitis, CMI, NH Lic #133
HomeCheck Professional Home Inspections LLC
Derry, NH
603-432-3211
Inspecting New Hampshire and Southern Maine
http://homecheckhomeinspections.com/
"Always think long term, do not be influenced by short term thinking or rewards."
Old 6/30/14, 11:41 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Default Re: Unsafe water heat vent
Nice draft hood. NOT
As a Professional Home Inspector, I support the privacy of my clients.
For more information click Trustyourinspector.ORG
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
hydronic radiant floor heat on hot water tanks mnicholet Plumbing Inspections 7 4/14/10 5:48 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
