Old 3/10/11, 11:48 AM
Default Unvented S-trap
Does any have an illustration of how to change an unvented S-trap into an acceptable drain arrangement when venting is not possible. AAV's are allowed here but since they can't be installed in verticle piping, I'm not sure if that helps.
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/10/11, 12:13 PM
Jeffrey R. Pope's Avatar
Default Re: Unvented S-trap
Proper drainage cannot be accomplished without proper venting. If venting is "not possible," I would conclude that the fixture does not belong where it is.
"AAV's can't be installed in vertical piping?" What do you mean by that? AAV's are only installed in a vertical position.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/10/11, 2:04 PM
Isn't the whole purpose of an AAV to provide venting where proper (ie the usual means of) venting is not possible.
Our plumbing code says horizontal
Air admittance valves shall,
(a) only vent
fixtures located on the same storey, and
(b) be connected to the horizontal
fixture drain.
Old 3/10/11, 5:48 PM
Yes.
The AAV is installed vertically on a horizontal line.
S-traps are improper. In order to properly install P-trap, there must be a horizontal line.
(picture stolen from another thread)
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/10/11, 6:07 PM
So is there a way to convert an unvented S-trap to a P-trap and AAV?
Old 3/10/11, 6:47 PM
Christopher Currins's Avatar
A way.
Christopher Currins
Certified, Licensed
Old 3/10/11, 6:55 PM
Yup, that will do it. Thanks.
Old 3/10/11, 7:18 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
And this.
774 Manor Road
Staten Island, NY 10314
718-514-3393
Old 3/10/11, 8:55 PM
Originally Posted by jgromkoski View Post
And this.
Interesting. No vent required?
Old 3/10/11, 11:02 PM
Jeffrey R. Jonas's Avatar
The horizontal pipe (distance requirement) breaks the siphon.
Old 3/11/11, 10:05 AM
But that's not a particularly long horizontal arm. The horizontal arm on a conventionally vented P-trap arrangement is usually longer than that and venting is still required.
Old 3/11/11, 11:25 AM
Doesn't need to be longer than 2x trap diam.
On a conventional system, the vent must be within (3 or 5 ft) (US/Canada) (local AHJ). Same applies here. Adding the horiz. section breaks the s-trap configure. The horiz. section is needed before the vert. drop to break the siphon.
Visualize the system from the fixture to where it connects to the waste/vent stack. Can you visually confirm the system to meet standards? If not, call it out.
Old 3/11/11, 1:03 PM
In an older home where the S trap was acceptable I just make my client aware of what it is and what the potential issues are. I never say it is necessary that it be vented because that was the acceptable configuration at the time. I suggest that it can be improved if desired and give them the diagram with the solution. I also like the added AAV configuration but they are not allowed here.
774 Manor Road
718-514-3393
Old 3/11/11, 2:54 PM
Thanks guys, good thread.
Old 3/14/11, 10:04 AM
Steve McRae's Avatar
Steve McRae Steve McRae is offline
This configuration was in kitchen and bathroom of my last inspection. I think they tried their best to get good drainage, but they maybe didn't know about the serious uphill slope to the drain in the crawlspace...
McRae Home Inspections
Goderich, ON
519-955-3277
Condensation Drain line question acassady Inspecting HVAC Systems 25 2/26/12 11:40 AM
Trap weird and crown weir dpant Plumbing Inspections 22 1/24/11 11:41 PM
Trap Primer Question jallingham Plumbing Inspections 5 2/15/08 7:36 PM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/14/06 11:00 PM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 5:41 PM
