Any advice on how to write this contraption up. It flushed, took about 3-4 minutes to stop.
I have never run into one of these and do not know of what probelms they typically have. Last edited by mashburn; 2/6/08 at 6:29 AM.. |
This toilet needs to be upgraded. It needs a sewage ejector.
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Toilet appears to have been installed on the wrong floor of the home in question...blah blah blah.
Sorry can't help more, only seen one of these.....and it wasn't on an inspection.... I'll wait to see what answers you get, then steal them |
That's funny.
Ugrade is an under statement, call a plumber. Looks like DIY, could only salvage the valve and not the storage tank. ha. ha. http://www.plumbingsupply.com/toilet...ehightank.html Vent is to small and fitting on the vent line is backwards. Seeing the 2" water supply pipe, you would think that the supply could have been increased, but on the other hand, you don't see 2" cold water supplies to often in a house, so that might be page 2. ha. ha. Was this connect to the four inch waste to the right? Who knows right. That is a good one. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I told buyer to remove the outdated, incomplete, sewage sucker! Did not want to spend too much time reporting this condition.
The buyer, friend of a good friend, said she would have someone come and remove it. Everyone laughed about it. Thank you for your responses. |
Totals looks like a DIY, also looks like the floor next to the toilet is wet, definitely a substandard installation, recommend evaluation by a licensed, qualified and insured plumber.
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
| efficiency of 15 yr old peerless | afrost | Inspecting HVAC Systems | 11 | 11/19/07 9:51 AM |
| Septic Systems | Rick Sovastion | General Inspection Discussion | 28 | 7/31/07 9:55 AM |
| functional flow | dbucknavich | Plumbing Inspections | 11 | 5/31/07 11:04 AM |
| Pressure and flow rate | rbennett | Plumbing Inspections | 4 | 10/2/06 8:56 AM |
