happychappy is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am looking for some guidance on replacing my water line from the meter to the house.
The meter is about 60ft from the house and I live in the Midwest (Illinois near St. Louis metro area). The current size of my house is 1600 sq. We are considering adding on in the future. 1. What size pipe should I use? 2. Will a bigger pipe make a difference? 3. What type of pipe copper , plastic ? 3. What code of copper pipe K, M, or L? 4. Soft or Hard pipe? 5. Should gravel be laid around the pipe in the ground? 6. What dept should the pipe be installed? 7. Anything else you think I might need to know? Thanks for your assistances . Steve Chapman |
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm from this area too.
Do you pay your water bill to Illinois American Water? What town do you live in? Last edited by ccbrands1; 9/12/06 at 4:42 PM.. |
caseyville water
Fairview Heights |
Hire a licensed Plumber, and get a professional to stand by his work.
Steven Waskewicz Rest Assured Inspection Services, LLC. 719-510-7703 mobile all the time 719-495-7166 Fax. s_waskewicz@msn.com HVAC Lic. #10722 EPA cert.544143239730 www.restassuredinspection.com NACHIiid=NACHI06032370 |
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am a licensed plumber. I would suggest your hire a plumber to do this. If you have to ask all those questions it is above your head. There are many things that can go wrong if not professionally replaced.
| smelly well water | afrost | Ancillary Inspection Services & Additional Topics | 22 | 11/21/07 8:30 PM |
| More water, different windows | Brenda | Exterior Inspections | 12 | 9/22/06 3:55 AM |
| Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? | jwatts1 | Plumbing Inspections | 8 | 7/29/06 12:50 PM |
