Inspected a 4000 sq ft home this morning that had all Moen fixtures in the home. Home is 5 yrs old. PEX type plumbing. Here is the problem; The two faucets in the upstairs master bath did not work at all, also another faucet in bathroom down the hall had VERY low pressure, water just dribbled out. Faucet next to it worked fine. Two other bathroom faucets worked fine. The other problem; No hot water at all four shower mixer valves, cold only. I know that Moen mixer valves can go bad if they sit unused for long periods of time, but all four? Could this be the same problem with the two handle faucets? All fixtures are in excellent condition, like new. I checked all shut valves.
Mary Ann Chiquete Serving the entire Phoenix Metro Area 623-399-7962 www.benchmarkazinspect.com benchmarkaz@gmail.com |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Did you check the shut off valves at the manifold, or just at the fixtures?
Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President
Did not find manifold in home,or at least access to it. I rarely do here in AZ.
Mary Ann Chiquete Serving the entire Phoenix Metro Area 623-399-7962 www.benchmarkazinspect.com benchmarkaz@gmail.com Last edited by mchiquete; 2/20/12 at 4:44 PM.. Reason: clarify |
If it has PEX, it has a manifold. Not all manifolds use shutoff valves, but for a home that size they are common. It was probably behind an access panel. If you havent filed your report already, I recommend you insert a statement stating that you did not discover the location of the manifold, and to request the location from the seller.
Thanks, I have seen manifold access panels in garages in some homes, but not very often. I even looked in attic. Home is bank owned, so I will just note in report that manifold was not located.
Failed water softener in the house?
2011 InterNACHI Member of the Year Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
I haven't seen a PEX Manifold in any home built here in the last 10 years. I'd bet its the mixing cartridges, I find they fail especially if the house has sat all last summer during the extreme heat.
Dale Duffy InterNACHI 2007 U.S.A Member of the Year National Association of Commercial Building Inspectors and Thermographers™ |
No water softener installed in home
Thanks Dale, this is what I thought, but it is strange that so many went bad. It just had me scratching my head.
It's an easy and inexpensive fix on a moen faucet and about all that can go wrong with them...
I've even seen one extreme case where someone zoned the copper piping! (If I come accross the pic's. I'll come back and post them). Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President
Mary Ann, I find bad mixing cartridges daily...sometimes 3-4 in a shaq...so what you found is not out of the norm to me.
It's a flip of the coin here, but many are still plumbed the traditional way without a manifold.
are You seeing much pex there Bill...it's just starting to show up here....
Every thing here is PEX now very seldom to see a manifold
| Upstairs Sewer Gas and Basement Lift Station | Merc Man | Plumbing Inspections | 4 | 12/24/10 11:29 AM |
| Homes often are rush jobs, critics assert | tmantsch | Miscellaneous Discussion for Inspectors | 0 | 3/17/06 6:54 PM |
