Old 12/23/10, 10:50 PM
Merc Man Merc Man is offline
Please Note: Merc Man is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Upstairs Sewer Gas and Basement Lift Station
I am so glad I found this site. I hope someone can help me.
I live out in the country and have a septic system. We have a lift station or sewage/water pump in the basement that pushes all of the water and sewage from the one basement bathroom/shower and the laundry room out to the septic system. The water and sewer on the main level of the house is gravitied out to the septic system.
When we wash clothes or take showers in the basement we get a strong sewer gas smell in the upstairs bathroom. If I run water into the upstairs tub and sink to put more water in the traps. The smell will go away. I think what is happening is that when the lift pump runs in the basement during high water usage is that it somehow also moves the water out of the upstairs bathroom traps. What's weird is that it doesn't seem to bother the kitchen trap that is also upstairs. Has anyone ever experienced any thing like this? If so do you have a fix? We've been dealing with it for about 20 years. Thanks in advance for any help or suggestions. MERC
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/24/10, 8:20 AM
Sean Fogarty's Avatar
Default Re: Upstairs Sewer Gas and Basement Lift Station
It sounds like you have a venting problem, or lack of a vent for that section of the plumbing. Why don't you give a plumber a call. NO one can give your a good answer by your description here. Who ever comes and looks at it will give you a better answer
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 12/24/10, 10:17 AM
Roy D. Cooke, Sr's Avatar
Exactly...... Great answer....
Old 12/24/10, 11:05 AM
Greg Keene, CPI's Avatar
Greg Keene, CPI Greg Keene, CPI is offline
A venting problem would also be my guess. My neighbor had a similar problem and found one vent had been filled with pine straw as it sat directly under a pine tree. Over the years the vent stack filled up and stopped venting. A goose neck vent top solved his problem (after they cleaned out the vent). This may be why the kitchen is not affected but the bathrooms are. Different vent stacks.
Greg Keene
Clear Choice Home Inspections
Evergreen, CO
303-674-3234
greg@clearchoice-hi.com
Old 12/24/10, 11:29 AM
Robert Ernst Robert Ernst is online now
I think these guys are right on. I would agree with the venting issue. If the vents are working it would suck in air and not water. You or a plumber can go on the roof and check the vents for obstruction like was mentioned. Look inside with a flash light. There could be an animal or nest inside. If there is something inside there you don't want it to fall down inside. But since you said it's been like this for 20 years I would make sure that the pump itself is vented properly.
