Old 3/1/09, 2:00 PM
Jonathan T. Hittle's Avatar
Jonathan T. Hittle Jonathan T. Hittle is offline
Default What is this valve?
I am a licensed plumber and I hate to admit that I have never seen one of these. Any ideas? It is on the incoming line from the well. It has open setting in the middle and graduated degrees going up each side. No other markings or numbers. Thanks for any help!!
Old 3/1/09, 2:25 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Default Re: What is this valve?
it has some writing on it but i cannot read it... is that something to do with a filter system? future use?
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 3/1/09, 3:43 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
maybe to control flow.
http://images.google.com/imgres?imgu...US306%26sa%3DN
Old 3/1/09, 4:34 PM
The writing was just open and the stages of degrees you could open or close it. It was like a balancing valve of some kind. There was an elaborate filtering/softening system. OH SOFT softeners. It really doent matter to the buyers they are going to ask the sellers but I was wanting to know for future reference.
Old 3/1/09, 5:58 PM
tdietrich1's Avatar
Is there an external appliance? BBQ, Water Heater, etc.
Tom
Old 3/1/09, 8:35 PM
No, appliances that Ican tell.
Old 3/1/09, 8:52 PM
Looks like a circuit setter of some sort for pressure and flow.
Hope someone can identify it.
I am curious too!
Old 3/1/09, 10:47 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
I think it is an Air Eliminator typically used in Hydronic Heating systems.
Air eliminators are used in liquid systems to aid in the removal of air and other gases. Many systems designed for liquid service do not operate well when air is present. One example would be flow metering. Most flow meters are designed around volumetric measurement principles. Air passing through a flow meter gets measured just as if it were a liquid, causing large flow measurement errors. An air eliminator, mounted to the top of a stilling chamber and installed upstream of the flow meter, will vent this air, and only liquid will be presented to the flow meter.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 3/1/09, 10:54 PM
Wayne B. Wilson's Avatar
Mario
I don't think it is at least it doesn't remind of anything i have seen , Unless things have changed in the last few years, I was looking at what Robert posted, more in that line i think. LOL this is like a easter egg hunt
Old 3/2/09, 10:05 AM
Originally Posted by wwilson3 View Post
Mario
That was my best guess Wayne!
Tel.# 416-722-6132
Old 3/2/09, 1:06 PM
Mario , I hope we can figure it out it is like the valve that Robert showed but i am wondering if the had either a softener or A pond out front. It sure looks like it has the ability to control flow . So is it cold up there? My buddy was saying they have had record snow fall for the winter. But that is a little further north than you.
Old 3/2/09, 1:57 PM
Well, since we are all guessing
Am I getting closer?
Jandy 3-Way Valves
The Jandy 3-Way valve never needs lubrication and is guaranteed to never fail. The diverter seals are made of a proprietary material that will not leak or break during the life of the valve. The CPVC construction is resistant to temperature and chemical fluctuations and is designed to allow maximum water flow while maintaining structural strength. Every Jandy valve can be automated using a Jandy JVA valve actuator.
Marcel
Old 3/2/09, 2:10 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
Since we're all guessing, a water usage meter (?)
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 3/2/09, 2:18 PM
cwillick1 cwillick1 is offline
is there a built in pool/hot tub or a sprinkler system
Old 3/2/09, 2:37 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
I am going to take a WAG without seeing what the valve face looks like or having a clearer shot. I think it is to limit the flow/pressure for the main water supply. Here is an interesting web page that I found that might shed some light into the valves identification.
http://www.wellowner.org/awellmainte...pressure.shtml
It is possible there might be additional booster pumps installed at the well that would create a pressure to great for the home's plumbing system to handle.
Seisco TWH does not need a TPR valve? jyost Plumbing Inspections 4 10/6/08 9:01 PM
Sprinkler System Vacuum Breaker Valve sbenson Plumbing Inspections 5 9/12/08 3:41 PM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
