Old 8/16/06, 10:07 PM
mmorgan mmorgan is offline
Default Vent??
In the picture, I think the taller of the two pipes is supposed to be the vent. Its not doing much good as is. Besides that, it terminates inside the home.
Old 8/16/06, 10:26 PM
Jeffrey R. Pope's Avatar
Default Re: Vent??
Some jurisdictions will allow installation of an AAV here. It looks like they installed/relocated the laundry hook-ups and just didn't know what to do with the vent.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/16/06, 10:27 PM
Paul Pendley Paul Pendley is offline
Default Re: Vent??
Isnt the vent on the wrong side of the trap?
Paul Pendley
Premier Property Inspections
866-458-8516
Old 8/16/06, 10:29 PM
Default Re: Vent??
Uhh, yep. Wow, I looked right past that
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/16/06, 10:33 PM
Mike Parks's Avatar
Mike Parks Mike Parks is offline
Please Note: Mike Parks is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Vent??
Opinion:
looks like they have a problem with the washer draining.
This other pipe was installed to take the extra water.
Unusual, but since there is a trap it may not be a big deal.
Still state that this is not a normal install.
See the difference than saying it is wrong?
Old 8/17/06, 9:40 AM
Default Re: Vent??
Yeah. My whole point of showing this was the fact the the vent was on the wrong side of the trap. Someone didn't know what they were doing when they installed this. Looks like one of those do-it-yourself jobs.
Old 8/17/06, 10:06 AM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Vent??
For my own education...
You referring to the fact that it's after the trap, instead of before it, correct?
Old 8/17/06, 12:28 PM
Default Re: Vent??
The vent is on the wrong side of the trap, it should be after the trap. Hope this helps.
Paul Pendley
866-458-8516
Old 8/17/06, 8:28 PM
Mike Parks's Avatar
Default Re: Vent??
If the vent, in this case, was after the trap you would have to have a 'Surevent' installed.
Old 8/17/06, 9:06 PM
Michael Larson's Avatar
Default Re: Vent??
Mr. Pope did mention that in the second post to this thread.
Michael Larson
Hudson, WI
[/I]
Old 8/17/06, 9:13 PM
Mike Parks's Avatar
Default Re: Vent??
Yes but I was posting to insure that I was understood. Correcting myself.
BTW a vent installed in the above example would serve no purpose.
Old 8/17/06, 9:23 PM
Default Re: Vent??
That also has been aluded to.
Old 8/21/06, 9:37 PM
dgagne1 dgagne1 is offline
Default Re: Vent??
so we all agree the vent, if that is what it was set up for, is on the wrong side of the trap. Maybe it was set up for two washers...
also, the stand pipes are toooooo long, momentum will blow out the trap.
Plumbing vent next to exhaust vent mpettitt Plumbing Inspections 5 10/12/07 5:38 PM
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 9:17 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
