Old 4/2/10, 4:08 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default vent hot water tank
Your thoughts on this are appreciated. Thank you.
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/2/10, 4:14 PM
James E. Braun, CMI's Avatar
Default Re: vent hot water tank
I like it. An elbow beeing used as a straight piece of vent pipe. Even looks like the pipes are two diferent sizes and they are actually using tape to join the two pipes together.
Call it as you see it.
Old 4/2/10, 4:17 PM
Also in my area, 1/2 " is not allowed as a supply line. Needs to be at 3/4".
Old 4/4/10, 8:10 PM
Banned
Man!!!! Why can't they do the simplest things right???
Within the last 4-5 weeks, called 2 oil furnace flue pipes taped to a different size fluepipe. What ever happened to reducer/increasers? They only cost $4-6.
Hopefully that is not a HVAC tech job!!
Expansion Tank On A Hot Water Heater rmarton Plumbing Inspections 6 2/28/10 3:41 PM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
