Is there a minimum distance required between these two, I believe te max to be 6'?
************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can't remember of ever hearing of a minimum distance but the disposer is wet vented, as many are it seems.
I don't think there's really much of a problem there since the disposer is on the bottom and it's vent gets the benefit of being flushed from the other trap. |
That would be a "waste stack" or a "combination waste and vent system." While I can't find anything prohibiting that particular installation, typically these systems are only considered for use in multi-floor dwellings, and all same-floor fixtures should enter the drain/vent at the same level.
At best, it shows the work of someone other than a "qualified plumber." IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 5/11/07 at 11:30 AM.. |
Jeff, I agree with you as all I could find was with multi-floor also. The home is newer and on a septic... I think the owner was pretty "handy". Thanks for your input. Shawn
| Plumbing vent next to exhaust vent | mpettitt | Plumbing Inspections | 5 | 10/12/07 5:38 PM |
| waste pump under kitchen sink | tjansson | Plumbing Inspections | 3 | 5/11/07 2:15 PM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 9:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
