Not sure if this pipe is acceptable. Vent pipe is a small flex pipe going into a larger pipe. There is no seal on the pipe where it is connected.
That pipe is not acceptable. Cannot be flex pipe.
It looks to me like that is a listed, flexible B-vent. I'm not sure it's installed properly (the pic is a bit small) where it enters the other vent.
Do you have a better picture? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I agree with Jeff. Always look for a label on vent pipes. They do make flexible B-vents.
Looks like an old AO Smith water heater, hope you looked for rust around the bottom seam.... Or, as I do, recommend replacement just due to the age.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
