Old 12/9/07, 7:23 AM
nbhi's Avatar
nbhi nbhi is offline
Default Vent Pipe?
Do any of you have a clue as to what this would be for, the flexable pipe. This is the main water shutoff coming in.
Attachment 16614
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 12/9/07, 7:29 AM
Michael Larson's Avatar
Default Re: Vent Pipe?
I'm guessing there used to be a water softener/conditioner at that location. The flexible line was for the drain connection.
Old 12/9/07, 7:34 AM
David P. Valley's Avatar
Gary,
Are your meters at the street out there in Ohio?
Why aren't there individual shut-offs at the branches?
Old 12/9/07, 8:13 AM
nbhi's Avatar
David
Not normally. They are in the house. This is a slab home, could not locate water meter.
Old 12/9/07, 8:20 AM
Originally Posted by nbhi
David
That's what I thought. This may not be the Main Water Shut Off.
Old 12/9/07, 8:48 AM
nbhi's Avatar
You are right David. There would have to be a meter after the shutoff, Duh.
Old 12/9/07, 9:36 AM
In Massachusetts, we have the shut-off (to the water main) before and after the meter. Some homes only have one verses the other. I always manage to locate the water shut-off in order to show my client. If the shut-off is not located (which is rare), I red flag this in the report.
Old 12/9/07, 11:30 AM
Charley L. Bottger's Avatar
Same here David Okla Sop state we must identify location of main shut off and report the same water and gas.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 12/10/07, 3:51 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
The meter is probably in meter pit in front of house. The valve is probably the required shut off inside the house (they call it the main). The real main (depending how you look at it) is in the meter pit. As far as the plastic hose, it could be abandoned condensate drain.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 12/12/07, 2:31 AM
Frank G. Ross Frank G. Ross is offline
My guess is a water softener drain
Pillar To Post Professional Home Inspection of SW Utah
Serving all of Iron and Washington Counties including the cities of St. George, Cedar City, Beaver, Brian Head, Duck Creek and more.
Check out our website www.pillarposthomeinspection.com
Growing our business by leaps and bounds every day!!
Frank G. Ross
Certified Home Inspector
C.T.R.
(Certified ~ Trained ~ Reliable)
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Vent pipe dlee2 Plumbing Inspections 4 9/17/07 11:28 PM
