Old 2/17/06, 8:39 PM
bmargiotti bmargiotti is offline
Please Note: bmargiotti is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default vent termination ?
greetings, let me set the scene... bungalow with newly remodeled master suite with glamor bath upstairs.
here i saw a roof vent that extended up about 8". issue i saw was the skylight that was about 6" away from the vent. i told the homeowner that because of the opening, the vent had to extend 2ft from the roof. she was arguing with me and told me an architec did the remodeling, blah, blah, blah... there are no different circumstances because the skylight are there? i dont think so, but...
thanks,
Bob
Old 2/17/06, 8:43 PM
David P. Valley's Avatar
Default Re: vent termination ?
Bob,
Roof vents are not limited as to their location or height. There's no problem installing a roof vent right next to a window or skylight. It's simply allowing hot air to escape the attic cavity. That hot air that is escaping is not a health issue. It's breathable.
You must be thinking of a Plumbing vent. If that were the case, now we have an issue.
Plumbing vents can not be installed to within 3 feet of any building opening.
Old 2/17/06, 8:47 PM
yea, its not a roof vent. a plumbing vent.
Old 2/17/06, 8:53 PM
Here ya go...
Old 2/17/06, 9:30 PM
gbeaumont's Avatar
Hi to all,
Bob, is the skylight operable (openable) if it is a fixed pane it is not an issue, if it is opperable, then its an issue as Dave said.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 2/18/06, 9:04 AM
Originally Posted by gbeaumont
Hi to all,
Regards
Gerry
Thank you, Gerry.
Operable does make a big difference, ayy?
Old 2/18/06, 10:31 AM
gbeaumont's Avatar
Originally Posted by dvalley
Thank you, Gerry.
Hi Dave, yes it does
From IRC 3103.5
P3103.5 Location of vent terminal.
An open vent terminal from a drainage system shall not be located less than 4 feet (1219 mm) directly beneath any door, openable window, or other air intake opening of the building or of an adjacent building, nor shall any such vent terminal be within 10 feet (3048 mm) horizontally of such an opening unless it is at least 2 feet (610 mm) above the top of such opening.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 2/18/06, 10:42 AM
jrivera's Avatar
jrivera jrivera is offline
Please Note: jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
This place is worth every penny of $289.00.
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 10:17 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 6:22 PM
Vent termination thejnicki Plumbing Inspections 4 10/1/06 3:27 PM
Dryer Vent termination tneumann Miscellaneous Discussion for Inspectors 8 3/24/06 7:39 PM
