Old 11/27/06, 8:07 PM
Kenneth Blair Kenneth Blair is offline
Default venting the kitchen sink
This kitchen sink vented into the cabinet under the sink. Is this something to report or is it okay?
venting-kitchen-sink-dscn0204.jpg   venting-kitchen-sink-dscn0205.jpg   venting-kitchen-sink-dscn0202.jpg
Old 11/27/06, 8:21 PM
Doug Edwards's Avatar
Default Re: venting the kitchen sink
Kenneth,
I can't tell for sure because none of the photos have a real clear shot at the device on top the white PVC. I "suspect" the black object is an "Air Admittance Valve" although I personally have never seen one made of ABS plastic. We see many these made of PVC especially if the sink is in an island or peninsula in the kitchen. We also see many in bathrooms. I have seen an increase in the use of these in new construction because that means one less hole cut thru the roof for DWV.
Old 11/27/06, 8:28 PM
That is what I was thinking the black piece was too. I was concerned about the venting it into the cabinet. I guess since it is common there, then it is acceptable. This is the first one I have seen underneath a cabinet. Sorry about the pics, but those are the best I could get.
Old 11/27/06, 8:29 PM
Kenneth;
This appears to be or might be an Air Emittance valve.
I would recommend checking with the AHJ to make sure they are allowed.
Here in Maine they are illegal. Can no longer be used.
Marcel
</IMG></IMG>
Old 11/27/06, 9:40 PM
Donald R. Peterson's Avatar
Donald R. Peterson Donald R. Peterson is offline
Oatey sells an inline valve available at the HD
Try tis link
http://www.oatey.com/apps/catalog/sh...&prodgrpid=278#
Don Peterson, CMI
AmeriDream Home Inspections Inc.
NYS License: 16000014560
Old 11/27/06, 9:44 PM
Well..there you go. The second black ABS plastic AAV in one day. In the words of Inspector Clouseau..."We have esol ved the case"
Old 11/27/06, 10:06 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Here is some info about air emittance valves.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 11/28/06, 2:37 AM
Russel Ray's Avatar
Here's a section on air admittance valves that I uploaded to About Homes a couple of days ago and is in my Interactive Report System.
Air admittance valves
Old 11/28/06, 7:09 AM
Jeffrey R. Pope's Avatar
I've never heard of an AAV being referred to as a wet-vent Russel. The term "wet-vent" is defined by codes as - "A vent which also serves as a drain."
Mechanical vents, such as these, are prohibited by most jurisdictions in CA. This application in CA, most likely, would have utilized an "island fixture vent."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/28/06, 7:54 AM
Jeff
I have also not heard of them referred to as "wet vents",but I have heard of the phrase "cheater Vents".
Tel.# 416-722-6132
Old 11/28/06, 8:12 AM
David A. Andersen's Avatar
They are used here all the time at the kitchen sink. This is because the current style is not to have the kitchen sink and against a wall where a conventional vent would easily be utilized.
One thing to check is that the vent must be 4 inches above the drain piping (it appears that it is in this photograph). I will often see them too low.
Old 11/28/06, 10:41 AM
Russel Ray's Avatar
I hear it sometimes down here, and it was common usage in the areas where I lived/worked in Texas and Louisiana. I never ran across them in Detroit, Philadelphia, or Tampa.
That is why my exposé states "sometimes" called a wet vent.
They are quite common here in San Diego, especially in the newer subdivisions, and really especially in the newer, richer subdivisions because the obnoxiously wealthy don't want all those ugly things sticking through the roofs.
Old 11/28/06, 10:42 AM
Russel Ray's Avatar
I have heard "cheater vents" as well but don't like the connotation associated with the word "cheater." I also don't use the term "cheater plugs" when dealing with electrical outlets.
Old 11/28/06, 11:05 AM
I've heard them referred to as "cheaters," but more commonly as "flutter vents." Possibly due to the noise they make.
That's the reason for the island-fixture-vent. It doesn't go through the roof, it's simply a "loop vent." I'm sure you've seen them.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/28/06, 11:22 AM
With "special permission," you can do just about anything you want. This is how they are doing it in a newer tract just inside of Ventura County.
The entire pluming system shares one main vent, terminated in the attic. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Island sink venting question ehyde Plumbing Inspections 4 7/13/07 1:36 AM
waste pump under kitchen sink tjansson Plumbing Inspections 3 5/11/07 2:15 PM
Outlet under kitchen sink adooley Electrical Inspections 3 2/13/07 2:50 PM
Kitchen sink & outlets lprinzi Electrical Inspections 3 6/8/06 5:52 PM
