Old 1/21/08, 6:29 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default W/M drain trap below the floor
I was reviewing a plumbers evaluation and he mentioned that the washing machine drain had a "below the floor trap". He didn't specify if it was an issue, but I don't know why else he would have mentioned it. (the entire line is 1 1/2" and not vented so he wants to replace the entire line).
Is a washing machine drain 'below the floor' trap an issue (as long as the standpipe is the proper height)?
Thanks.
Old 1/21/08, 6:39 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default Re: W/M drain trap below the floor
I thought that for an automatic clothes washer, if a standpipe is used, the standpipe and its trap shall be at least 2 inches in diameter. ??
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Old 1/21/08, 6:50 PM
rbrady's Avatar
It is, and that's why he is recommending replacement of the entire line. His report mentioned the below floor drain, but did not deal with a repair specific to the trap because the entire line is going to be replaced anyway.
Old 1/22/08, 11:51 AM
rbrady's Avatar
Due to the lack of responses, I assume (I know ) there is no issue with a below the floor trap.
After sleeping on it, I think the plumber may have mentioned the below the floor trap because of a comment in the home inspection report that a trap was not noted. (difficult access)
</IMG>
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
Ill inspector 2nd floor laundry floor drain? ebethel Plumbing Inspections 1 7/18/07 9:59 PM
Air leak from floor drain yolhovsky Plumbing Inspections 5 2/24/07 6:43 AM
