Old 8/10/11, 12:16 AM
Mike D. Freeman Mike D. Freeman is offline
Default Warm Cold Water
Just looking for a second opinion. Had a inspection today and the cold water seemed warm so I took temperatures and it ranged from 88 to 90. I let the water heater heat back up and retested with the same results. The water would go from cool about 75 then rise to 88 to 90. The only conclusion I can come up with is there is a cold and hot water line crossed somewhere. This is a slab foundation.
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/10/11, 9:50 AM
Charley L. Bottger's Avatar
Default Re: Warm Cold Water
Had this problem on a house I inspected the plumber found a shower/tub faucet that was leaking internal causing a cross connect and mine was a slab floor also these can be a B**** to find sometimes
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/14/11, 12:56 AM
Frank L. Bartlo Frank L. Bartlo is offline
Definitely reads like a cross connection. Was that one particular fixture or room, or the entire building?
Old 8/14/11, 7:14 PM
Jeffrey R. Pope's Avatar
It may be difficult to isolate, but easy to verify if it's a "cross-connection" from a bad mixing valve or similar.
Turn off the supply to the water heater and run the cold-water for several minutes, then check it's temp. Continue running the cold-water while you restore the supply to the water heater. If the cold-water rises in temp, there's a cross-connection somewhere.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Water Pressure Problem dcossar Plumbing Inspections 19 11/21/09 8:47 PM
Hot water heater Hot and Cold hookup phughes Plumbing Inspections 20 5/11/06 1:04 AM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
