Old 11/29/06, 9:03 PM
thejnicki's Avatar
thejnicki thejnicki is offline
Default Washer Drain
Drain from a clothes washer, Would anyone consider this an S-trap?
Old 11/29/06, 10:43 PM
jking2 jking2 is offline
Default Re: Washer Drain
It's a P trap if it meets up with a vent stack in the wall.
Old 11/29/06, 11:50 PM
Tim
Looks kinda funky. Just guessing, but makes me think someone had to retro fit/repair the standpipe or fittings, outside the finished wall cavity. How old do you think the original installation is?
Old 11/30/06, 12:42 AM
thejnicki's Avatar
The house all together was kind of funny to tell you the truth, I think the laundry was relocated from the upstairs out to the garage.. That might explain it.
Old 11/30/06, 11:02 AM
Looks like a normal washer drain pipe to me, exposed in the room rather than in the wall.
Abraham Lincoln
Old 11/30/06, 11:22 AM
Jeffrey R. Pope's Avatar
Common P-trap. Looks good to me. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/30/06, 6:11 PM
Drain, William. D r a i n. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/30/06, 6:22 PM
Not to worry, William...
Just move it over here: http://www.nachi.org/forum/f20/dryer-vent-10539/
Larry Kage, CMI
231 929 3525
Old 12/1/06, 7:22 AM
wsiegel wsiegel is offline
Sorry about that. Have had the flu lately and my head must be in the clouds. The post has been moved. Thanks for picking it up quickly.
Busy Washer Drain jgilleland Plumbing Inspections 3 11/21/07 9:54 AM
French drain tied into main drain rwashington Plumbing Inspections 6 2/17/07 12:04 AM
drain pan for washer rjennings Plumbing Inspections 16 5/11/06 2:33 AM
Washer Secondary Drain roconnor Plumbing Inspections 7 4/2/06 2:02 PM
Proper distance between a washer drain pipe and 220 volt dryer connection rpaul Electrical Inspections 14 1/3/06 10:43 PM
