Old 2/20/08, 4:43 PM
Charles L. Harper's Avatar
Charles L. Harper Charles L. Harper is offline
Arrow Washer Pan
I know this has been discussed before but.............
I recently discovered that there is no requirement for a pan under a washer in an upstairs laundry room. Builder was very adament about not having to put pans under washers anymore. Cheap bastards. Anyway this house has a laundry room upstairs with no pan. I did call it out, as a concern. House also has a water heater in room adjacent to laundry and of course a pan is required here. I do not understand the logic...or lack of logic. Just venting.
Charlie
Old 2/20/08, 5:04 PM
Dale Duffy's Avatar
Default Re: Washer Pan
Charlie
Yep, you nailed it right Charlie.....
Old 2/20/08, 6:07 PM
Bob Elliott's Avatar
I always suggest a drain pan for washers.
With all the condo units I do maybe two had them and one had a drain line in place but no pan.
Anyway I always tell people to get a pan even if there is no drain.
You know you could go further and add them to dishwashers too, though that might not work out to well with the baseboards or the space.
Old 2/20/08, 11:43 PM
Charley L. Bottger's Avatar
I have a better idea lets just build the house inside a big drain pan and not have to worry about leaks at all
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/28/08, 7:53 AM
Joshua L. Frederick Joshua L. Frederick is online now
in my years doing plumbing I have come to the conclusion that pans are about worthless. Its no different than having anything upstairs that uses water & could possibly leak, toilet, tub valve, etc.
Old 2/28/08, 8:24 AM
Here it is Bob.
http://www.floodsaver.com/
Marcel
Old 2/28/08, 9:05 AM
mnahrgang's Avatar
Here's another option instead of a pan.
http://www.onsiteproducts.com/affiliates/19.htm
Mark Nahrgang
www.HeyMark.info
Busy Washer Drain jgilleland Plumbing Inspections 3 11/21/07 8:54 AM
Washer Pans charper Plumbing Inspections 9 6/22/07 12:35 AM
Washer Drain thejnicki Plumbing Inspections 8 12/1/06 6:22 AM
drain pan for washer rjennings Plumbing Inspections 16 5/11/06 1:33 AM
Washer Secondary Drain roconnor Plumbing Inspections 7 4/2/06 1:02 PM
