Ran across an unusual situation I thought I would kick around here.
Second floor closes washer which has a trapped primary drain to the DWV system with an air gap (okay so far), and a secondary overflow pan below the washer with a trapped pipe to the exterior just above a gutter ... hmmmm. It just rubs me the wrong way ... I guess it could be a potential freezing problem, and there would be discharge of waste wash water into a rain drainage system ... even though it's only a secondary drain. Seems like it should have the secondary drain to the DWV also, or at least a float switch in the pan to lock out power to the washer if there is an overflow (instead of the drain to daylight). But I don't see this situation addressed in any references, model codes (e.g. IRC), or local codes. Any thoughts? Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
I have seen the second story laundry secondary pans tied into the Primary drain line here in Phoenix. I have also seen no pans, and I always point out the lack of a pan on a second floor.
It would only drain if there was a problem, and it is just gray water.
I don't think the intent is for graywater drainage, however, even if it were, graywater systems are not required to tie into the DWV system. I would think that a "conspicuous" location would be warranted, which is typically what I find in new construction.
But into a roof gutter? Sounds like a shortcut to me. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Go easy on yourself Brian. . .
Jeff ... in my neck of the woods waste from both toilets and all other fixtures (i.e. greywater) is required to be directed to the DWV system and discharge to a septic disposal system, as we are on an IRC based codes. This includes clothes washer waste water, which must be connect to the DWV system through an air gap ( IRC P2718 ).
The only reason I wouldn't red flag the install is it's a secondary emergency pan for the clothes washer water. I think it's just wrong, but the situation doesn't appear to be covered by model codes ... other than the code requirement for all waste water (including that from a clothes washing machine) to be directed to the septic system. Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Busy Washer Drain | jgilleland | Plumbing Inspections | 3 | 11/21/07 8:54 AM |
| Washer Drain | thejnicki | Plumbing Inspections | 8 | 12/1/06 6:22 AM |
| drain pan for washer | rjennings | Plumbing Inspections | 16 | 5/11/06 1:33 AM |
| Proper distance between a washer drain pipe and 220 volt dryer connection | rpaul | Electrical Inspections | 14 | 1/3/06 9:43 PM |
