I know there is alot wrong with this picture. The plumbing is infront of the electrical panel, the washer stand pipe and the water heater vents out the side wall.
What do most of you recommend when you see stand pipes installed like this when the sanitery sewer is this high off the floor? |
| Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I would recommend installing a laundry tub with pump and discharging the washer in tub.
Marcel Gratton, NACHI04011210, CMI, NHI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Just curious but what is the hose is for as it looks too small for a washer ?
Yep that is the only solution as the standpipe is to short and too high.
I believe the other line would be a condensate from the AC or High Efficiency Furnace. THE RIGHT TRAK CIAQP, IAC2 Board Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq apoteyes@gmail.com Cell: 705-971-2096 Ph : 705-946-2676 |
What makes it too high besides looking funny ?
Some older washing machines would have trouble with that height. Most modern washers have a stand pipe height maximum of 8 feet and a minimum of 30 inches.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Could be the backwash line for a water softening system.
Russell Inspection Services LLC New Hampshire state license # 57 Level I Thermographer, ITC Building Science Thermographer, ITC Building Analyst, BPI Commercial Inspector, ITA Certified Septic Evaluator, GSDI #148 www.newenglandthermalimaging.com www.russellinspectionservices.com www.nhsepticinspection.com Serving Alton, Alton Bay, Wolfeboro, Laconia, Gilmanton, Gilford, Meredith, Center Harbor and the entire Lakes Region |
If you meant discharge being too high then it most likely is the septic tank location.
The clear plastic hose into the drain looks like a softener backwash drain. Unfortunately, I see a lot installed like this. Functionally, this open connection WILL fill the basement with waste water when the main drain plugs one day. Yes, that open pipe should be extended at least to the roof line.
| Washer standpipe | jfrederick | Plumbing Inspections | 5 | 8/19/11 9:15 AM |
| Washer Drain Pipes | Rebecca Jennifer | Plumbing Inspections | 0 | 4/21/11 11:35 PM |
| Maytag washer recall | Mark Thorman | Interior Inspections | 0 | 8/25/10 9:15 PM |
| Sewer gases when washer empties | sbutts | Plumbing Inspections | 13 | 4/28/08 7:28 PM |
| Washer Secondary Drain | roconnor | Plumbing Inspections | 7 | 4/2/06 1:02 PM |
