Basement W & D setup. This washer drain line was added to main plumbing stack just to the right of dryer (& this pic) via a 3" to 11/2" saddle clamp/fitting.
What's the minimum height for a washer standpipe? What would be some of the potential concerns, if any, with this set up? Thanks in advance. |
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
See illustration for height. Water overflowing due to improper height would be one concern.
pic appears afoul
? illustration for dimension accuracy 2012 IRC P2706.2 Standpipes. Standpipes shall extend not less than of 18 inches (457 mm) but not greater than 42 inches (1067 mm) above the trap weir. Access shall be provided to standpipe traps and drains for rodding. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 8/19/11 at 8:02 AM.. |
Barry: The IBC is maximum in this instance that is an error and don't wish to discuss why. I am not a plumber.
Less is better and the maximum applies to what you should not do. We want to follow the InterNachi guidelines for reasons of proper research. Ask a plumber and he may or may not know. Ask an inspector and he should know why. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Is that the only reason standpipes have a minimum height?
Joshua
Ask Barry as he seems to be the authority on stand pipes. |
| Washer Drain Pipes | Rebecca Jennifer | Plumbing Inspections | 0 | 4/21/11 11:35 PM |
| Maytag washer recall | Mark Thorman | Interior Inspections | 0 | 8/25/10 9:15 PM |
| short standpipe | dokeefe | Plumbing Inspections | 3 | 9/21/09 8:16 PM |
| Sewer gases when washer empties | sbutts | Plumbing Inspections | 13 | 4/28/08 7:28 PM |
| Washer Secondary Drain | roconnor | Plumbing Inspections | 7 | 4/2/06 1:02 PM |
