Old 8/10/07, 3:15 PM
kweiss's Avatar
kweiss kweiss is offline
Default Washing machine drain suds overflowing
Had a client this morning describe a problem for which I have no answer. So I thought I would post it here.
The problem:
When the washer drains they get suds, not actual water, overflowing from the drain opening. While no water comes out, it is of course wet.
They have had the builder out, who has supposedly for some reason scoped the pipe and confirmed no blockage.
They have had an appliance guy out who says everything is fine with the machine.
They have changed soap brands/type and amounts.
They brought the washer with them when they moved and did not have this problem in their old house.
While I can think of a number of reasons for this drain to back up and overflow, I can't come up with any for it to cause just suds to overflow. The circumstances seem to indicate that it is a problem in the drain plumbing. A vent problem?
Any ideas?
Old 8/10/07, 4:04 PM
David P. Valley's Avatar
Default Re: Washing machine drain suds overflowing
Sounds like their using too much soap.
They tell you that they cut down the amount, but did they really?
I'll bet it's the soap amount.
Old 8/10/07, 4:06 PM
Roy D. Cooke, Sr's Avatar
The problem:
Any ideas?
Dish washing soap instead of dish washer soap will do it every time .
Try washing with no soap and if the water runs away I expect this is the reason.
.... Cookie
Old 8/10/07, 4:09 PM
Originally Posted by rcooke
Dish washing soap instead of dish washer soap will do it every time . Cookie
Roy,
Do you think they could be that idiotic?
Old 8/10/07, 4:12 PM
Jeffrey R. Jonas's Avatar
Could also be their water hardness. Did they have "hard" water at their old home, and this home has very "soft" water? You can usually get "free" water hardness test strips at Lowes...just ask for them.
Old 8/10/07, 4:15 PM
Roy,
Yes seen it done more then once .
I give up on trying to be sure people do not make mistakes .
If it can be done some one will do it.
I have not lost the sugar yet but my grandmother did found it in the freezer.
...Cookie
mnahrgang's Avatar
In my younger years, my new wife and I tried regular dish soap in the dishwasher when we ran out one time. It was truly hilarious, and looked like a skit from an old I love Lucy show. Suds all over the kitchen. I even ended up having to take the dishwasher outside, and hoseit out, because rincing just made more suds. Idiotic? No, just ignorant. Sometimes what you don't know, can be pretty funny.
Mark Nahrgang
www.HeyMark.info
Old 8/10/07, 4:26 PM
What I don't understand is that they didn't have the problem in their old house. But now that they moved, there's suds everywhere.
Whatever they were using and doing at their old house, I'm sure they brought their washing habits with them.
I'm baffled......
Old 8/10/07, 4:30 PM
Michael Larson's Avatar
Hard water will not produce suds if real soap is used.
A simple test for soft water is to add a drop or two of real soap to a small vial and shake.
If it's soft it with suds nicely.
If not there will be little or no suds and the water will be cloudy after shaking.
Detergents however will suds in soft or hard water.
Old 8/10/07, 4:40 PM
kweiss's Avatar
I cannot say with absolute certainty how much or what type of soap they are using. I saw the laundry detergent box for what they use now. They say they are not using too much - who knows on that front.
I suggested all the basic things like running it a few times without soap, running some vinegar through it to help remove buildup, etc.
I don't think this is a water thing, as I have lived around here for 25 years and worked in inspection or related businesses for 15 or so and never heard of this paritcular complaint.
My best advice was to get one of those newer drain hoses that have the molded rubber plug type thing that caps the drain and holds in the hose. I figure that will keep the suds in.
Old 8/10/07, 5:19 PM
I wonder as said above they are comming from very hard water needed lots of soap now softer water needs less soap.
yes as you said run it no soap and see what happens .
........ Cookie
Old 8/10/07, 9:08 PM
Donald R. Peterson's Avatar
Donald R. Peterson Donald R. Peterson is offline
Mr Weiss,
Is the washer drain entering into a standpipe? If it is, what is the length and diameter of the standpipe? Also if using a standpipe what is the distance from the trap of the standpipe to the 1st unobstructed vent?
I have seen short standpipes and flexible traps that were buried inside walls create this issue. The ridges on the flexible buried trap creates turbulence and excess suds. Also every time i have seen this it has been a 1.5" dia standpipe.
Hope this helps
Don Peterson, CMI
AmeriDream Home Inspections Inc.
NYS License: 16000014560
French drain tied into main drain rwashington Plumbing Inspections 6 2/16/07 11:04 PM
Single lever washing machine valve phinsperger Plumbing Inspections 2 1/8/07 10:13 PM
