I found this on a water heater during a 1 yr warranty inspection. Anyone have any idea what it is for???? yes there is a recirculating pump on the water heater.
any ideas out there? |
Interesting setup. A electric water heater with a bypass valve upstream of the shutoff valve that dumps into the TPR discharge pipe. Is there solar water heating in this house?
The last picture is a hot water recirculation pump that may have been installed afterward the initial installation. It could also be part of a solar hot water heating system too. |
In this case the Pix are not giving enough of the story
rlb |
It looks as if it's a pressure relief valve. Maybe in case the pressure within the pipes is exceeded too high the valve will discharge relieving pressure on the pipes and potentially saving the joints from failure????? Hmmmm never seen one yet.
What does the tag on the valve say. Air Relief ??? Never seen one like it.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
I'm inclined to agree with Mark. Definitely looks like a pressure relief valve. Never seen one plumbed exactly like that, but have seen them on hot water radiant heating systems with circulating pumps.
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
what is a Wilkins HBRV?
no solar system on the house. the house is less then a year old. Not sure what the tag says right now, but I'll look and get back with you.
thanks for the help everyone! BUT I still have no idea what it is. |
The HBRV is for hose bibb applications but it looks very similar. |
Mike,
there is no hoes bib here. one end of the copper tubing goes from the T&P valve back to the top of the water inlet line. Could it be a pressure relief line to control the pressure coming into the water heater? As the pressure get too high it goes off and drains into the relief drain line? Monday I think I'll call the builder and then talk with the plumber to determine what it is..... |
As you said the device discharges to the TPR valve drain line and is used instead of of an expansion tank. |
I was thinking it looks like a setup for an outdoor sprinkler system.
What happens when the TPR valve needs to be activated? There is no way that tapping into the TPR drain line like that can be right. If it is I would sure like to know.
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Water Heater Dip Tube Failure | jacaron | Plumbing Inspections | 2 | 2/25/07 12:28 AM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 10:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 9:55 PM |
