Old 3/18/10, 10:47 AM
pnarron pnarron is offline
Default Water Heater Corrosion
The water heater is located in a closet that used to be a garage, which they changed into a bedroom. The closet is 10x4 and does have 2 vent pipes for combustible air, one is a couple ft from the overhead and the other comes down to about 2ft from the floor. They both vent into the attic about 3ft from the furnace. Is the corrosion from improper venting and the burners on the furnace have corrosion with irregular flame?
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/18/10, 11:24 AM
ldapkus ldapkus is offline
Default Re: Water Heater Corrosion
The corrosion in the furnace may be from a leaking A-coil drain line which is a pretty common source.
Old 3/18/10, 4:47 PM
Joe Funderburk, CMI's Avatar
I see corrosion like that on furnace burners a lot. Often it's the refrigerant line not well sealed and condensation is dripping into the cabinet. Address the problem, whatever it is. The burners themselves are probably fine.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/18/10, 4:48 PM
Water heater looks like it could use a plumber to check it out. Probably old too.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/18/10, 5:52 PM
Doug Edwards's Avatar
I would be more concerned about the gas fired water heater being in a closet off of a converted garage, made into a bedroom. A double bozo no-no!
- John Stuart Mill
Old 3/18/10, 6:00 PM
Jeffrey R. Jonas's Avatar
Beat me to it!
Old 3/18/10, 6:12 PM
Just barely!
- John Stuart Mill
Hot water first then cold out of cold side of fixture jberthiaume Plumbing Inspections 19 3/12/08 1:32 AM
Water Heater Dip Tube Failure jacaron Plumbing Inspections 2 2/24/07 11:28 PM
Water heater corrosion - help please... bwooddell Plumbing Inspections 6 2/10/07 7:17 PM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 11:50 AM
