LinkBack (4) Thread Tools
  4 links from elsewhere to this Post. Click to view. #1
Old 2/2/07, 12:40 PM
John M. Acaron's Avatar
John M. Acaron John M. Acaron is offline
Thumbs up Water Heater Dip Tube Failure
Just came across this issue, keep it handy you might need to inform your client. Inspected Once, Inspected Right!!!!!!
Water heater manufactured between 1993 and 1996. During this period many water heaters were fitted with a faulty dip tube during manufacturing.
A dip tube is a pipe that routes water coming into a gas or electric water heater toward the bottom of the tank. Perfection Corporation is the manufacturer of 90% of the dip tubes used in domestic water heaters. This includes the most popular brands like: State, A.O. Smith, and Rheem. The Consumer Product Safety Commission has not issued a recall because they did not find a safety concern with the failures.
When the dip tube fails, the amount of usable hot water may be significantly reduced and faucets may become clogged with plastic pieces of the failed tube. If the dip tube breaks off toward the top of the tank it improperly allows the cold water to discharge into the top portion of the tank rapidly cooling off the hot water. This can create a very short supply of hot water. In other cases, the problem is less pronounced and it may not be detected during a home inspection. A failed dip tube is repairable without a complete tank replacement and it may be covered under warranty provisions. Along with the dip tube replacement, it is very important that the tank be drained, the home's interior supply lines flushed, and the faucet aerators cleaned.
  • Dip Tube Specific Hot-Line Phone Numbers:
  • A.O. Smith call 1-800-323-2636
  • American Water Heater call 1-800-999-9515
  • Bradford White call 1-800-531-2111
  • Rheem, Ruud, Richmond call 1-800-621-5622
  • State Industries call 1-800-821-2019
  • Other water heaters - contact a knowledgeable plumber
HOMEINSPECTORUSA, LLC
www.HOMEINSPECTORUSA.biz
Old 2/2/07, 11:19 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Water Heater Dip Tube Failure
I've replaced over a hindred did tubes because of this failure. Ironicly, the dip tubes were made by Perfection Corp. Guess they didn't live up to their name.
If the homeowner complains of showers not lasting long or aerators clogging with a milky white debree that will turn to paste in your finger then I would suspect the dip tube.
Old 2/25/07, 12:28 AM
Peter Doane's Avatar
http://www.nachi.org/forum/showthread.php?t=12802
Peter Doane
NACHI ID# 05120681
LinkBacks (?)
LinkBack to this Thread: http://www.nachi.org/forum/f22/water-heater-dip-tube-failure-12999/
Posted By For Type Date
White chunky bits , found in water faucet screen , and it causing low water presure ??? - Yahoo! Answers This thread Refback 10/22/08 7:49 PM
Why does my hot water not last long anymore? - Yahoo! Answers This thread Refback 10/6/08 8:05 AM
Yahoo! Canada Answers - Why does my hot water not last long anymore? This thread Refback 9/30/08 9:19 PM
Is my water water heater broken? - Yahoo!7 Answers This thread Refback 9/14/08 9:42 AM
Client wants a new water heater adirienzo General Inspection Discussion 47 7/14/10 3:03 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 10:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
