Old 2/26/11, 7:17 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Default Water heater drain
Water heater drain line was dripping during today's inspection. Ran water for dishwasher and checked for hot water in bathrooms only. Found the drain dripping, it stopped after awhile. Anyone know why it would start and stop? 17 year old heater.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/26/11, 7:33 PM
Christopher Currins's Avatar
Default Re: Water heater drain
bad valve.....17 yrs. old
Christopher Currins
Certified, Licensed
Old 2/26/11, 7:48 PM
Shouldn't it leak all the time though?
David
518-505-8305
Old 2/26/11, 8:48 PM
Brian E. Kelly's Avatar
Define two things, "All the time" and "Leak".
You observed it leaking, report that and move on.
Old 2/26/11, 10:20 PM
Bruce A. King's Avatar
It would have to be related to changes in water temp at the lower portion as cold water enters (thermal contraction) to cause the problem to come and go. Or, the tank pressure went up during a period of heating with zero hot water usage that caused thermal expansion to cause the problem to show up.
It might need a thermal expansion tank or valve added in addition to a new water heater. I would never advise repairing a tank that old except as a temporary fix by replacing the leaky drain valve. The next leak will probably be much worse.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 2/26/11, 10:44 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
The heater is past the normal lifespan. Don't waste money or time changing the valve. Put a garden hose cap on it for $2.99 and replace the heater when needed.
Stephen Stanczyk
Old 2/27/11, 12:53 AM
Stephen -
I sure hope you're joking, because if NOT and you cap the guys TPR valve or drain line / YOU just made a 4 1/2' tall hand grenade that could kill somebody.
Old 2/27/11, 1:16 AM
Jeffrey R. Jonas's Avatar
Originally Posted by dbowers View Post
Stephen -
Talking about the 'tank' drain, not the TPR drain. At least that is how I read post #1.
Old 2/27/11, 1:18 AM
Stephen -
It is not the TPR drain line. It is the drain valve that is leaking. (see original photo) Capping that would do no harm as it is designed to be closed.
Stephen Stanczyk
Old 2/27/11, 1:21 AM
Bob Elliott's Avatar
I think Dan mis read it.
Perhaps one only needs to turn the handle clockwise
Old 2/27/11, 1:23 AM
Is it just me, or does that TPR drain 90deg elbow look to be a size reduction?
Old 2/27/11, 1:26 AM
It looks like an optical illusion. If you blow it up, it looks better. But then if I take my glasses off, it looks like there are two of them...
Stephen Stanczyk
Old 2/27/11, 1:32 AM
Anyone else notice the support post?
Old 2/27/11, 9:39 AM
Yes I did. It's in the report.
David
518-505-8305
Old 2/27/11, 11:15 AM
You're right, I hadn't blown up and looked at pic. When he said drain line leaks I thought TPR and ...... CAP it, you gotta be joking .... Please tell us you're joking.
Sorry Stephen
hydronic radiant floor heat on hot water tanks mnicholet Plumbing Inspections 7 4/14/10 5:48 PM
On Demand Water Heater dgagneur Plumbing Inspections 10 3/30/08 10:57 PM
Water Heater Dip Tube Failure jacaron Plumbing Inspections 2 2/24/07 11:28 PM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
