Should this water heater exhaust be so close to this window. It is 49inches away from it.
J.Szczesny 4 Seasons Home Inspections Washington State Inspector # 711 800 5th Ave #101-385 Seattle, Wa 98104 (206)391-0285 online @ www.4seasonsinspects.com email @ info@4seasonsinspects.com toll free cal @ 866-512-9972 "For the best protection, get the right inspection" |
| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Had one last month just like it. Did some research and that application is fine. I think I saved the link but it is on my tablet and not available till late tonight.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
It must be a Washington thing because it would have been called out in my area.
Just wondering, on what basis would you call it out? A direct vent water heater has specific venting requirements based on the Btu's of the unit. Either more or less than 50k Btu. In either case, it is more than 12" away from the window.
Thanks Stephen
It looks like it is less than 18 inches from the corner.
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
So then those shingles would only be 3 inches each? Chuck |
Where does the 18" come into play? Sidewall? I don't think that bump out would be a sidewall due to the angle but that is just opinion.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County Last edited by sstanczyk; 9/4/10 at 2:38 PM.. Reason: another look. |
1) where located next to walkways, the termination shall not be less than 7' above the level of the walkway 2) Vents shall terminate at least 3' above any forced air inlet located within 10' 3) Where located below an adjacent roof structure the termination point shall be located at least 3' from the structure 4) The vent system shall terminate at least 4' below, 4' horizontally from, or 1' above any door, window or other gravity air inlet into the building 5) The vent termination point shall not be located closer than 3' to an interior corner formed by two walls perpendicular to each other 6) The vent termination shall not be mounted directly above or within 3' horizontally from an oil tank or gas meter 7) The bottom of the vent termination shall be located at least 12" above finished grade Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
| Water Pressure Problem | dcossar | Plumbing Inspections | 19 | 11/21/09 8:47 PM |
| Weird water heater problem | kweiss | Plumbing Inspections | 3 | 4/5/09 6:34 PM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| Exhaust fan in room with gas water heater and furnace | jweinberg | Inspecting HVAC Systems | 7 | 2/18/06 1:23 PM |
