Has anyone ever seen this - The unit said it was a sealed system, There was no venting at the top at all. This was in a mobile home. Thanks for any help
Chris Mainka Owner/Inspector www.mainkas.com facebook.com/Houston.Home.Inspector www.linkedin.com/in/homeinspectorhouston Home Inspections preformed in Houston and Surroundings Areas TREC#10327 |
| Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
it just looks wrong
lol Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
this was from yesterday....
It doesn't look right to me either. The vent on a water heater isn't usually that big. The thing is in mobile homes they usually require furnaces and water heaters to be listed for use in a mobile home. Die to their small size and being pretty air tight the gas appliance are more likely to have spillage into the home. Did you notice the cap that was on the roof? This could be a double pipe brining in the fresh air.
WOW! 6 violations in 3 pictures.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Yes.
Typical. ????? On the rooftop??? That's most certainly a safety hazard if not. |
grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
Chris, that is a Residential Direct Vent Manufactured Home Gas Water Heater. Go to the State Industries web site click on view instructional manual, then go down to select MH SV & DV click on pdf 2919340
| Weird water heater problem | kweiss | Plumbing Inspections | 3 | 4/5/09 6:34 PM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 8:55 PM |
| Exhaust fan in room with gas water heater and furnace | jweinberg | Inspecting HVAC Systems | 7 | 2/18/06 1:23 PM |
