mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Has anyone seen one split open if so what would have caused it? I am looking for all reasons not just pressure.
Thank you |
Factory defect.
Bad TPRV, allowing the expansion tank to fail rather than the TPRV opening. Installed on the outlet instead of the inlet. Wrong pressure in bladder. Just a few I can think of anyway, but I could be wrong--- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Along with what Dale said above, expansion tanks also come in various sizes. The size you need depends upon two very important variables. You need to know the capacity in gallons of your hot water heater and the water pressure of your house piping system.
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
The reason I asked; where I work (real job) I noticed the expansion tank on the restroom water heater had split and been removed. Someone had capped the line and just left it. I pointed it out to the Safety guy and he called the maintenance super who told him that (the only thing the tank is for is extra storage)
Michael...here's a pretty good technical paper on w/h expansion tanks for you reading pleasure:
http://cid-be8dc000bc5ea1f7.skydrive...mExpansion.pdf |
Thanks for the help guys.
never heard of skydrive before ,hmm
Got the photos now. What do you think?
This happened in June.
Take a bicycle pump and see if the bladder is still intack. Pump it up a little and take a pressure reading. I bet it is probably blown, but if it is still intack it is probably a manufacture defect. if the bladder doesn't hold air still, it could be because the bladder failed and built up pressure inside the tank from a bad TPR valve not functioning properly.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree that it could have experienced excessive pressure due to a improperly installed or malfunctioning TPR valve. |
Most bladder tanks have a schrader valve on them to adjust the air volume/pressure. If the valve leaks, the tank will fill up with water. Same thing can happen is you get a leak in the bladder. The air will eventually absorb into the water. If you have a PRV or check valve on the main line, there is no place for expanding water to go. If you have a stuck TPRV at the water heater, the weakest link in the piping system will break. The real concern here is that you may have a stuck TPRV at the water heater. A bomb waiting to go off!!!
Two things come to mind. 1) Manufacture defect. Tank blew a below rated pressure. 2) There was some nasty pressure (and possible temp) in that tank. Bad TPR or plugged TPR. Either way some testing is in order.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
After blowing up the picture, it says 160psi max. Water heater could easily exceed that. Not supposed to, but it could.
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing Inspections | 16 | 9/18/06 8:55 PM |
