Old 9/29/09, 8:18 AM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Default water heater flue pipe
Is the metal tape ok around the flue?
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America)
Old 9/29/09, 9:47 AM
James E. Braun, CMI's Avatar
Default Re: water heater flue pipe
In my area it is excepted, but I would like to see the hose fastened on the water better than tape, such as some screws.
Old 9/29/09, 10:18 AM
Bob Elliott's Avatar
Screws are required at the hood connection ,and you need double wall in an un heated space.
Due to condensation issues.
Here is a good article.
http://www.checkthishouse.com/water-...vent-pipe.html
Old 9/29/09, 11:37 AM
Jeffrey R. Pope's Avatar
Screws are not required and should not be used on B-vents, as they are self-locking. This appears to be a B-vent, but I can't tell for certain. If it's not, it's improper. B-vents are required for heat vents in the attic or other concealed locations.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/29/09, 1:41 PM
gkay gkay is offline
Please Note: gkay is a non-member guest and is in no way affiliated with InterNACHI or its members.
Richard that venting doesn't look right to me. it appears that a short section of 4" flexible aluminum chimney liner has been attcahed to the b-vent with tape. Tape is not an acceptable way to secure any type of vent pipe servicing a gas appliance. Screws are required at the water heater draft hood and this b-vent to flex connector is used to connect the flex (see link) Jefferey is correct that b-vent should be used for the entire length. The b-vent exiting the roof doesn't appear to be properly secured or straight.
http://www.novaflex.com/productcart/...&idproduct=389
Old 9/29/09, 3:20 PM
From that picture the hood to vent connection looks crooked and dependent on tape.
Old 9/29/09, 8:25 PM
Salvatore j. Vivona Salvatore j. Vivona is offline
I dont like it at all the flex pipe the tape yheres no fire proofing around the heater
Old 10/15/09, 12:36 PM
Bruce Thompson's Avatar
Bruce Thompson Bruce Thompson is offline
Is it me? That looks like a section of flexible aluminum dryer exhaust!!
Bruce Thompson
Professional Inspector, Lic. #9199
Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area.
www.TylerHomeInspector.com
NACHI 06081394
Old 10/15/09, 1:13 PM
mnahrgang's Avatar
It could be, but there is also flue piping that looks like this too. I got caught on that recently with a furnace...
Mark Nahrgang
www.HeyMark.info
Old 10/15/09, 4:21 PM
For example:
Double Wall Flexible Gas Vent Connector
www.selkirkcorp.com/WorkArea/downloadasset.aspx?id=7674
Larry Kage, CMI
231 929 3525
Old 10/16/09, 11:40 PM
hmmm.....
Bruce Thompson
NACHI 06081394
Old 10/17/09, 12:08 AM
Originally Posted by lkage View Post
For example:
I have seen them but do not recall how i determined they were that type off hand.
Anyone know a good quick way to tell they are double wall.?
Old 10/17/09, 1:05 AM
Chuck Lambert Chuck Lambert is offline
Unmoderated Guest
Please Note: Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
They are actually single wall rated as double wall. Look at the connections as they are self locking and single wall are screw together. On the connections is the rating sticker. I see it all the time and have it on both my furnace and water heater.
Chuck
Old 10/17/09, 1:25 AM
Paul Pendley Paul Pendley is offline
Same here.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 10/17/09, 1:28 AM
For example:
Does not look the same...but im looking at a picture. I think its a dryer vent attached from my view point.
Paul Pendley
866-458-8516
