Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
How would you call this? I say the gas line is too short. It's tight against the tank and the bend radius has been exceeded.
What would you have them "evaluate?"
Personally, I don't see it as much of a problem. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
There should be slack in the line and the line should have a bigger radius bend before it connects to the water heater.
A drip/dirt leg would be nice
Looks ok to me, just. The bend radius on those lines is about golf ball size or so.
Twist the water heater around a bit. We stopped putting dirt in our gas a while ago Michael. |
The installation as shown would not be a problem in my neck of the woods.
It amounts to a sloppy installation. This condition is unusual on new construction here. Have not seen many drip/dirt legs here..
I agree with the comments, in general (sloppy work, etc.); however, I would personally be careful about using such terms as "bending radius is too small" unless I could say what radius is acceptable for the flex being used.
Frank, You are right I should say "the bending radius may be too small". The bend radius should be no less than 1.5", or about golf ball size.
Reading Spending time with other HI's talking about such things like we are doing here. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Hey Michael - We agree! Dirt leg is SOP in Midwest (or at least from Kentucky North). Anywhere the supply line turns Down.
Brian - we've got old wells and our NG gets dirty. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
| Sulphur smell | bsmith | Plumbing Inspections | 2 | 6/6/08 8:32 PM |
| Hot Water Heater Question | mpeterson | Plumbing Inspections | 8 | 3/31/07 1:59 PM |
| Hot water heater question | mgeddie | General Inspection Discussion | 15 | 6/7/06 1:00 PM |
