Old 11/27/11, 12:00 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Water heater hookup...need advice.
The Gas line ran from the wall to the TPR valve the back to the
water heater.....Looks illegal from my training. Need feedback.
An Ounce of prevention is better
than a pound of cure :}
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/27/11, 12:18 AM
Jeffrey R. Pope's Avatar
Default Re: Water heater hookup...need advice.
It's a Watts 210 gas shutoff valve. This is a proper installation.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/27/11, 1:47 AM
Thanks Jeff....
Old 11/27/11, 2:45 AM
Bob Elliott's Avatar
Interesting.
I've never seen one of those.
Goes under the heading "unusual" in my files.
Old 11/27/11, 9:22 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Make sure there is still a properly installed TPR designed to 210 F/150 PSI and downspout six inches from the floor OR DRAIN This is primary protection and not to be mistaken with this set up of a WATTS 210 gas shut off.
Changed to prevent confusion.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/27/11, 9:26 AM
Michael Larson's Avatar
Originally Posted by kwood View Post
Make sure there is still a properly installed TPR designed to 210 F and downspout six inches from the floor. This is primary protection and not to be mistaken with this set up of a WATTS 210 gas shut off.
Please show us where that is a requirement
Michael Larson
Hudson, WI
Old 11/27/11, 9:46 AM
KEVIN WOOD's Avatar
I will let a plumber chime in and explain. If no one does and you can't figure it out look at the instructions for installation.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/27/11, 10:18 AM
clambert2 clambert2 is offline
Please Note: clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
A TPR valve is not required however a pressure relief valve is. It is usually located near an exterior hose bid. The watts 210 shuts down the gas in an over temperature situation and the pressure relief valve opens in an over pressure situation. They work together and must both be installed
Old 11/27/11, 10:21 AM
The watts 210 and pressure relief valve replace the TPR set up
Old 11/27/11, 10:39 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
So who is right? Kevin, did you f u c k up again?
Old 11/27/11, 10:41 AM
KEVIN WOOD's Avatar
We call it a TPR in Canada. Temperature/Pressure Relief Valve.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/27/11, 11:16 AM
TPR valves have a temperature probe that must extend into the water heater tank, they work on temperature and pressure thus the name. Pressure relief valves work on pressure only.
TPR valves and pressure relief valves are two completely different things.
In my area Watts 210 valves and pressure relief valves are found on interior water heaters where a traditional TPR and drain line will not work (drain to the exterior)
Old 11/27/11, 11:17 AM
Correct - a TPR valve is a combination temperature & pressure relief valve - which is not required when using a Watts 210 gas shutoff valve.
A standard pressure relief valve is required to be used in conjunction with the Watts 210 gas shutoff valve.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Intallation specifcally requires a pressure relief valve
Old 11/27/11, 11:18 AM
Correct.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
