Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
Old 2/14/07, 10:49 PM
Bruce A. King's Avatar
Default water heater at interior closet
New one level house on a slab, water heater in equipment closet on same level as the living space.
I know the water heater needs a pan but does the pan require a drain?
www.BAKingHomeInspections.com
704 301-3207
Old 2/14/07, 11:03 PM
Marc D. Shunk's Avatar
Default Re: water heater at interior closet
P2801.5 Required pan.
Where water heaters or hot water storage tanks are installed in locations where leakage of the tanks or connections will cause damage, the tank or water heater shall be installed in a galvanized steel pan having a minimum thickness of 24 gage (0.016 inch) (0.4 mm) or other pans for such use. Listed pans shall comply with CSA LC3.
P2801.5.1 Pan size and drain.
The pan shall be not less than 1.5 inches (38 mm) deep and shall be of sufficient size and shape to receive all dripping and condensate from the tank or water heater. The pan shall be drained by an indirect waste pipe having a minimum diameter of 3/4 inch (19 mm) or the outlet diameter of the relief valve, whichever is larger.
P2801.5.2 Pan drain termination.
The pan drain shall extend full-size and terminate over a suitably located indirect waste receptor or shall extend to the exterior of the building and terminate not less than 6 inches (152 mm) and not more than 24 inches (610 mm) above the adjacent ground surface.
Client wants a new water heater adirienzo General Inspection Discussion 46 5/18/09 11:27 PM
Water Heater Dip Tube Failure jacaron Plumbing 2 2/25/07 12:28 AM
Venting an oil-fired water heater mh718 HVAC 3 11/16/06 10:36 AM
TPR & Combusiton Air thejnicki Plumbing 16 9/18/06 9:55 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
