Old 6/6/08, 2:46 PM
Patrick J. Cloninger's Avatar
Patrick J. Cloninger Patrick J. Cloninger is offline
Question Water Heater Location
This gas water heater is located in the laundry room. The laundry room is upstairs. 9-10 yr. old home. The dryer is also gas. I saw no vents in the room and the door is hollow door (no vents). Is this acceptable?
Serving Knoxville and surrounding counties
Old 6/6/08, 3:01 PM
Michael Larson's Avatar
Default Re: Water Heater Location
Patrick, you may want to consider taking the advanced water heater course
Check the course material pack located HERE
Calculation of necessary venting requirements are covered in the course.
See section 11 in the course pack.
Michael Larson
Hudson, WI
Old 6/6/08, 3:33 PM
Thanks Michael. I mainly wated to know how much vent space is needed, ie. louvered door, vent at top and bottom of door, etc. I will check that out.
Old 6/7/08, 10:04 PM
rromoser's Avatar
rromoser rromoser is offline
check out the TPR drain...
Old 6/7/08, 10:14 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
OK, I'll bite. What's wrong with the TPR drain?
Stephen Stanczyk
Old 6/7/08, 10:38 PM
Christopher Currins's Avatar
It may be running uphill, but that could be the angle of pic.
Christopher Currins
Certified, Licensed
Old 6/7/08, 10:49 PM
Joe Funderburk, CMI's Avatar
"Combustion air ("make-up air") is required for gas burning appliances at a rate of 50 cu ft / 1000 BTU or else external ventilation is required. Due to the room size, that requirement may not be met (formal sizing calculations were not conducted). External ventilation openings should be within 12 inches (305 mm) of the top of the enclosure, and one within 12 inches (305 mm) of the bottom of the enclosure. No external ventilation was provided. Inadequate supply of combustion air results in incomplete combustion; products of incomplete combustion include carbon monoxide. The room housing the water heater may be inadequately ventilated for the purposes of providing combustion air and we recommend an evaluation and repair by a licensed plumbing contractor."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/7/08, 10:53 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have never seen a calculation to take into consideration the fact that the clothes dryer is actually creating a negative pressure (it is blowing air out of the room). The presence of a clothes dryer vented to the exterior makes it especially important for the appliance to have sufficient combustion air.
The amount of ventilation is fairly complicated. Check your Code Check Plumbing book. If you don't have one, you really should get one.
Old 6/7/08, 10:56 PM
Nooo. The photo? Aren't they supposed to install the water heaters at an angle like that?
Nice seismic straps also. oops.
Stephen Stanczyk
Old 6/7/08, 11:08 PM
I thought maybe the wall was leaning.. Just trying to give the guy the benefit of the doubt.
Christopher Currins
Certified, Licensed
Old 6/9/08, 7:29 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not to mention the ignition source is not elevated to the necessary 18".
Old 6/9/08, 7:50 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Stephan - 3 elbows to many.
Is it PVC or CPVC?
Does AHJ in Knoxville, TN require seismic straps?
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 6/9/08, 7:52 PM
Oh wait...nevermind. It is on the second floor, so it plenty elevated.
Old 6/9/08, 9:39 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Alright! Thank you! I'm sending you a gift, dude!
In the video, we calculate combustion air in a couple different situations.
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Old 6/9/08, 9:54 PM
Wasn't begging for a gift Ben but thanks.
The course was well done and useful.
I found the info on FVIR water heaters helpful.
Kenton did a fine job and Paige with the Bradford technician was a nice addition.
Michael Larson
Hudson, WI
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
