Old 4/21/11, 8:48 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Default Water Heater Pan Question
If a water heater is in a house that is a slab foundation and the tank is in the finished basement in an under the stairs utility closet and has no pan do you call it out and needing a pan ?
Thanks
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/21/11, 9:18 PM
Jeffrey R. Jonas's Avatar
Default Re: Water Heater Pan Question
Thanks
Jim
Contradictory statement. A basement home is not a slab home. But, that is not to say a basement does not utilize a slab floor.
If a water heater is installed over a finished space a pan should be installed.
If a water heater is installed within a finished space (ie... finished basement) and there is no drain closeby, I recommend a pan be installed.
Keep in mind, a pan will never contain the volume of water in the tank. It is primarily to contain small leaks, ie... drips, seepage, etc... until repairs can be performed.
Old 4/21/11, 9:23 PM
Good answer Jeff, I picked up on the contradictory statement also.
Old 4/21/11, 9:25 PM
alright alright I picked up on it also.... I just am used to referring to the bottom level of a 3 story townhouse as the basement level.
Jim
Old 4/21/11, 9:28 PM
Jim
Jim,
That statement is even more disturbing! Are you saying that the 3-story townhouse is on a slab foundation? Is that common there?
Old 4/21/11, 9:36 PM
Common here too Jeff for Condos.
Jim, I had a duplex on a slab up in Norther Maine in the 70's, and a drip pan should be installed. 20/20 is hindsight now, but I would always recommend a floor drain when it is constructed.
Old 4/21/11, 9:38 PM
Yeah tons of townhouses are just slabs and 2 and 3 levels built on them. Very common for townhouses here.
Jim
Old 4/21/11, 9:39 PM
Wow... guess it makes a difference with a 48" hard frost line vs. your ???
Old 4/21/11, 9:43 PM
Thanks Marcel, I always do I just wanted to get some other opinions, because this one inspaction I just did this past Sunday the sellers agent told the buyers agent who told me I was wrong ? Just because I recommended having a pan put under the water heater as the rest of that bottom floor is very nice and new carpet and tha old owner even said it has leaked before? I told both agents they should tell the new owner they will pay for the new carpets, and mold remediation if the water heater ever leaks. I did my job.
Old 4/21/11, 9:46 PM
You did Jim, and I always would say the same thing in that type of circumtance.
The least they could do for a poor design is pay for the carpet if something goes wrong.
Old 4/21/11, 9:49 PM
Originally Posted by jjonas View Post
Jim,
This style is very common around here
http://www.trulia.com/property/30433...llage-MD-20886
Old 4/21/11, 10:04 PM
Nice apartment, condo or whatever. Not enough cabinet space, they have to hang the pots and pans.
I did not see any receptacles in any of the pics.
How about pans for the washers on the upper levels and is the spacing of those ballusters exeed 4"?
I know, I ask too many questions.
Old 4/21/11, 10:10 PM
HAHA..good eye, that was just the listing, not my report, For a clean looking house I found a boatload of things to call out. But those style homes sure beat a nasty crawl space any day.
Jim
Old 4/21/11, 10:26 PM
Charley L. Bottger's Avatar
Not trying to piss in anyone's post toasties but answer me this if the water heater is installed in a basement under the stairs what good does a pan do if there is no place for the pan to drain into such as a floor drain the pan fills up and ruins the carpet anyway. Just saying
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 4/21/11, 10:47 PM
Bob Elliott's Avatar
Perfectly correct Charlie.
What percentage of the leaks are slow drips from faulty TPR valves in your opinion ?
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 9:18 PM
Hot water heater question carolinainspector Plumbing Inspections 9 6/19/06 1:59 PM
