Any one ever seen this type of material used for a water heater.? No where does it say "suitable" for water heaters, etc. Thoughts ?
Charlie |
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yep they sell it at lowes
Wonder how it does around the heat of the vent? Seems like it might melt the outer covering.
I have the same material on my electric HWT, it is much thicker than washing machine lines. It's been for 3 yrs now and no problems.
I used on a electric heater been on 6 years now no problem ( label said for Water heater use)
That saddle valve may be an issue later on.
Looks to be a pre drill galvanized type that often clogs up and I observe the right hand screw is looking rusted.Re check your side photo for a dielectric fitting at that 90. |
These stainless braided lines are sold up here in our Home Hardware stores, also avaliable with sharkbite connectors. Apperantly used often when I asked the store manager.
I've been using the supply lines for other supply applications for a few years now, with out any problems, and have noticed more and more plumbers using them. |
They are sooo much easier than sweating a bunch of elbows and pipes.
Check with your local codes if they are allowed. For example, we are not allowed to use braided or flex for hook-ups to water heaters.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Why do you have excessive heat around the vent?
Personally I like it better than the old galvanized I see everywhere.
When it looks Un-Professional....
I note as Un-Professional...... If the Seller finds a Plumber to say that the installation is OK...... What is the question....? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
| A few useful posts - I forget from whom | jmichalski | Plumbing Inspections | 12 | 3/30/06 9:06 PM |
| Water heater strapping in manufactured homes | ilpowell | Plumbing Inspections | 10 | 2/24/06 5:20 PM |
