Old 8/21/09, 10:59 PM
jwashington jwashington is offline
Cool Water Heater Pressure Release Mayhem
What do you make of this? I recently inspected a home with two older water heaters in California. The valves appear to go into a reduced size flexible line along with some sort of spicket attachment and finally it disappears into the wall to what I believe is into the plumbing vents. Ironically they contacted a plumber who stated that while the tanks were quite old, the valves were acceptable.
water-heater-pressure-release-mayhem-img_2224.jpg   water-heater-pressure-release-mayhem-img_2210.jpg
Find an InterNACHI certified Louisiana Home Inspector (and anywhere else in North America)
Old 8/21/09, 11:04 PM
Wayne B. Wilson's Avatar
Default Re: Water Heater Pressure Release Mayhem
I would ask for a letter stating that from the plumber if i was the buyer
Old 8/21/09, 11:16 PM
Jeffrey R. Pope's Avatar
They are (or the plumber is) full of sh!t. There is absolutely nothing "acceptable" about any part of this set up.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/21/09, 11:19 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
I would have to agree with Mr Pope. 100% Maybe even 150.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 8/21/09, 11:43 PM
Now now, the plumber is a professional lol, Maybe with a drinking problem but he is a professional
Old 8/22/09, 1:16 AM
Marcel Gratton's Avatar
These are unsafe installations.
I would question the plumber as to the location of the TPR valve on the WH in the first pic and reduce size of the discharge piping not to mention the use of galvanize piping...
On The Level Inspection
Gatineau, Québec
Old 8/22/09, 1:29 AM
Chuck Evans's Avatar
First Pic:
  • Valve not installed in tank (sensor is not inside the top six inches of the tank)
  • Not gravity draining
  • Valves not allowed on discharge line
  • Flexible connector reduces flow below nominal 3/4 inch pipe
Second Pic:
There may well be additional issues not visible in the photos such as "discharge does not terminate in a visible location"
Perhaps the valves were "acceptable", as the plumber stated, it's just that almost nothing about the way they're installed is.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 8/22/09, 10:01 AM
Jeffrey R. Jonas's Avatar
John,
I really hope you're just messin with us, asking about these set-ups. There is absolutely nothing right with them.
If you were just sharing your pics and find with us, thank you. It's always fun to see the 'carp' other inspectors find.
Jeff
Old 8/22/09, 1:31 PM
Certainly Jeffrey. The reality is that I definately was aware of the issues at hand, however it was very humorous that they took my recommendation of caling a plumber who did in deed state that the system safe and functional. Whats the world coming to? I did hghly recommend a second opinion though as well as printed off the TPR mini course for the client as reference.
Old 8/22/09, 3:48 PM
Second opinion? How about a qualified first-opinion?
Don't be delicate with this type of issue - it's a safety hazard in need of correction. Anyone who says something different is not qualified to give an opinion.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/28/09, 3:44 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would have to agree with all of the above with the exception of the use of the flex tubing. It is general pratice here and is not considered a significant enough of a reduction, but then again we're still on the 91 code.
www.MauiHomeInspections.com
Weird water heater problem kweiss Plumbing Inspections 3 4/5/09 7:34 PM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Water heater strapping in manufactured homes ilpowell Plumbing Inspections 10 2/24/06 6:20 PM
