Old 7/7/06, 9:25 AM
William A. Rosario's Avatar
William A. Rosario William A. Rosario is offline
Default Water Heater Pressure Valve
It could works but it is OK?
In order, apparently, not to have water inside the kitchen area, where also is the laundry equipment, this new house provides to customer a nice solution, connect a copper extension to the Pressure Valve an extend that throught the wall to the outside.
In this way whenever the pressure valve is activated then owner wont have problem with their kitchen equipment, but also, never will noticed when the pressure valve was shut, beacuse water just get to the outside.
Is this type of connection allow, I know it could works (I Hope)?
William
Old 7/7/06, 9:59 AM
Roy D. Cooke, Sr's Avatar
Default Re: Water Heater Pressure Valve
William
This would not be allowed in Canada also the discharge has been reduced from 3/4 to 1/2 it is not allowed to be reduced . .
Roy Cooke Sr
Old 7/7/06, 7:19 PM
Roy Cooke Sr
Thanks Roy very important detail!!!!!!
Old 7/7/06, 8:27 PM
Brian E. Kelly's Avatar
William
William, Roy is correct that you can not reduce the piping diameter on the PRV piping. Most of the PRV piping here is plumbed to the outside of the house.
Reverse Osmosis phinsperger Plumbing Inspections 3 10/30/07 7:28 PM
TPR valve acox Plumbing Inspections 19 5/27/07 1:36 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 10:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
