Old 6/30/10, 10:02 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default Water heater riser pipes
I know that the riser pipes at the top of a water heater should be rigid/sem-rigid (min. 18" I believe?), especially on a gas water heater near the draft hood. Anyway, can anyone show me any documentation/wording/pictures etc. to support this? I'm having trouble finding any information.
Thanks in advance.
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/30/10, 12:22 PM
Jeffrey R. Pope's Avatar
Default Re: Water heater riser pipes
Probably because there is no such requirement. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/30/10, 12:59 PM
mnahrgang's Avatar
They just have to be installed according to manufacturers instructions. If you google the make and model you might be able to find a digital copy of them, and confirm that your instance is according to those...
Mark Nahrgang
www.HeyMark.info
Longevity of Conventional Water Heater Tanks. lagudo Plumbing Inspections 8 9/7/08 6:13 PM
Water Heater Dip Tube Failure jacaron Plumbing Inspections 2 2/24/07 11:28 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
